Outdoor Kitchen/Bar and Pompeii WFO Build in Southern California
  • #16
    Concrete is poured and the posts are going up
    Now that the design is mostly finalized and the digging is done, things are going much faster now. I’ve got 7 out of 10 posts up. The roof structure should be complete within 2 weeks.
    <a href="http://n8sbar.servebeer.com/wp-content/uploads/2014/05/WP_20140513_009.jpg">
    Oven Thread
    Kitchen/Bar Thread
    • #17
      Side Beams are up
      Oops! Double post
      Oven Thread
      Kitchen/Bar Thread
      • #18
        Side Beams are up
        The side beams are now up. One is bolted with a notched post to beam attachment and 5/8-11 stainless bolts. The other side is simply clamped for now. The ridge beam will be next but that’s going to require some assistance, and some temporary bracing. It’s over 500 lbs. Hard to tell in the pic but it’s 5.25″ X 14″ X 22 Feet!
        Oven Thread
        Kitchen/Bar Thread
        • #19
          Re: Outdoor Kitchen/Bar and Pompeii WFO Build in Southern California
          Looks good. That is some serious timber you have there. Keep the pics coming.
          Cheers ......... Steve
          • #20
            Oven Thread
            Kitchen/Bar Thread
            • #21
              500 lb. ridge beam is up!
              Thanks to my small army, the ridge beam was up within 30 minutes. Piece of cake.
              Oven Thread
              Kitchen/Bar Thread
              • #22
                Oven Thread
                Kitchen/Bar Thread
                • #23
                  Nothing like having the numbers. Good job. That should go nowhere anytime soon.
                  • #24
                    Ditto, I rake out the ask when cold. But the benefit here in the UK is that the wood dries out under the oven with the heat. Darn, damp weather!!!
                    Originally posted by boerwarrior View Post
                    With all respect to Bill and Gulf,
                    my wood storage area is directly under my oven and I have had no issues. I generally only rake my ash long after the embers are cold, and I have had no issues reaching down and back for wood.
                    However I am still in my early 50's. Maybe when I am in my 60's I will feel differently about crawling under there!
                    Neil
                    • #25
                      All of the rafters are up. It's almost time to start on the roof.
                      Oven Thread
                      Kitchen/Bar Thread
                      • #26
                        Roof Sheathing
                        2X6 douglas fir solid sheathing being installed over the 4X8 rafters. Vapor barrier and exposed fastener metal roofing will cap the top.
                        Oven Thread
                        Kitchen/Bar Thread
                        • #27
                          Very aesthetic work. You're lucky in California is not a lot of snow. The distance between the rafters more than a meter! I can only dream about this conditions. We have snow load is about 200 kg per 1 sq.m. ;-( Therefore rafter section 5х200mm (~ 2x8 ") in my kitchen set in increments of 500 mm.
                          • #28
                            I like your work. To live where the only load the roof has to carry is the structure and some rain has to be a real bonus for those of us who have that. Cyclonic wind is the issue on this coast but Bundaberg is on the edge of where that would be expected.
                            The weather patterns are changing but I doubt snow will be an issue for my roof in my lifetime.
                            My other observation is that the cost of lumber of those dimensions would be prohibitive here but most people looking to build for the future build in hardwood that is structurally stronger even if it is more expensive and harder to work. Steel is the other option but the aesthetics are yours.
                            Looking forward to seeing the completed structure. It has some class.
                            • #29
                              Sorry that was a typo. I meant (and corrected) 4X8 rafters. I was originally going to use 2X8's on 24" centers, which is close to your 5X200mm on 500mm centers. I was going to use 1" T&G (tongue and groove) as sheathing. Then I saw a friends patio which used 4X's on 48" centers and really liked it. I Then realized that you can not use 1" T&G on 48" centers. 2X T&G was far too expensive so I went with ordinary 2X6 doug. fir. Still WAY more expensive than my original route, but I think it looks better. On the back section, hard to see in the pics, I had to add an extra rafter between two. Because of the odd angle, the span grows to almost 16'. In that one area I used 4X8's @ 24" spacing.
                              Oven Thread
                              Kitchen/Bar Thread
                              • #30
                                Exposed fastener roof
                                Got behind on my posts so it’s going to seem like this went up quick It did only take a week though…
                                Oven Thread
                                Kitchen/Bar Thread
