After a long talk with an old mason, he made a suggestion that I'm still pondering. After listening to what I wanted to build he told me that he would build it the exact opposite from the way I described.
I have been told to pour a 4" slab (patio) then build the kitchen on top of it. I intend to build the counters/islands with cinder block.
He said if he was building this for himself he would dig down 18", below the frost line, pour footers, then build the counters up from there. Then, after the cinder block structures have been built, either pour your concrete patio or lay pavers around them leaving a small gap.
I asked him why? He said simple: frost. Any slab of concrete laying on the ground is going to rise in a hard freeze. The ground simply pushes it up. When the ground thaws, it'll settle back down. Any structure built on top of it will move with it and this movement is not healthy for a cinder block structure. It will crack.
I told him that I intended to sheath it with stone and have tile on top for the counters. He reminded me that we have had a few mild winters lately but if we start having cold ones again a structure like I described will move and flex with the slab will not look so pretty in 5 years.
He said the movement isn't much; its barely noticeable but it does happen. The islands I intend to build will form a "J" shape so its more than just 1 run of block. It will take 2 turns and all be connected.
This may add to the total cost of my project but I love to do things right and not kick myself later for missing something.
Thoughts?
Thoughts?
. Well, from reading through this thread and understanding that you have frost in your area, is it really that deep 18"? Les, what are we, a foot? Well, anyways, if you are moving forward and it is not recommended to mortar the dome within 30 days of freezing temps, what is the game plan?
