For what it's worth, the cement folks said digging the footing ourselves would have saved $500, when I would have spent probably $350 and my weekend digging it myself. So I wouldn't bother because I'd be stressing and risking ending up paying more to do it myself.
I've attached a rough scheme of what I'm putting in. Day-to-day the dimensions will skew a little bit, but it's roughly 10 feet along on the vertical coarse, 16 feet on the diagonal, and then 9 feet on the diagonal. There's a sink in the vertical. The pizza oven will go where the diagonal meets the horizontal. A smoker goes on the end. The smoker is tight with the pool, and it's generally crowded right there with the pizza oven. However, we wanted both to be pointed towards the house; guests should then be attracted towards them, and I can check if my wife set the pizza oven on fire from a safe vantage inside the house.
As a side note, this is roughly what we paid an architect to tell us. It's only slightly different from our last plan before we got that help. I do want to complain that I felt like we were spending a lot of money on redrawing off a bad survey; the pool was never precise and I had indicated that. Also, I think I basically paid them to explain pizza ovens to them. On the other hand, they sharpened that plan a little and basically confirmed the aesthetics of the plan we had given. I won't ultimately complain because we had been through lot of schemes before settling on this rough idea. I will give the architect credit for suggesting poking the oven out a little. We have Live Oaks behind all this and I don't want to disrupt their roots.
There is an expanse there where I could probably dump something else in. I was thinking about building in some propane burners, but I don't really know what to do.
The smoke will be a vertical smoker with an offset chamber under the counter.
The electrician will be running the lines Friday and the concrete folks should be coming later in the month. I should be able to get all the bricks and crap dropped off at my house in April and then my agony truly begins.
