I've built a prep counter and bar on either side of my oven area with mortar/rebar-filled CMU structure for the base. I am putting quartzite slab as the surface (leftover from the kitchen remodel slabs). What is the appropriate underlayment material? I am trading between 1/2" cement board and 3/4 pressure-treated plywood. The cement board is rigid but not strong while the plywood is strong but not necessarily flat or as rigid. There will be steel rectangular tube supporting the overhang for the bar and I plan to bed them in with a layer of mortar or 50:50 sand/fire clay mix to level and continuously support them, then use Tapcon screws to attach the underlayment and steel tube to the CMU structure, and silicone adhesive to hold the slab in place to allow weather-related expansion/movement and seismic reinforcement. What are your thoughts on the underlayment choices? This will be exposed to the sun/rain if that affects your choice.
Countertop underlayment question
Id avoid pressure treated plywood outside 'cause it can warp over time. Cement board alone is not strong enough. Best option is a flat solid base like exterior grade plywood with cement board on top or a full mortar bed over the CMU
I ended up picking up a couple sheets of 3/4" ABX plywood. I'm going to bed them in with mortar to be flush with the steel rectangular tubing supporting the bar overhang. A sheet of roofing paper will act as a moisture barrier separating them from the masonry. Right now they are sitting on the patio table under a tarp for the moisture to equalizes so they lay flat.Comment
Hi everyone,
My name is Heiko. I’ve been following this discussion and found this topic really interesting because I’m currently learning more about outdoor kitchen builds and countertop structures.
For this kind of setup, I’ve seen both cement board and pressure-treated plywood used as underlayment, but I’m also trying to understand which option performs better long-term when exposed to moisture and temperature changes.
I’m mainly here to learn from experienced builders and understand real-world approaches rather than just theory. Looking forward to hearing what others have done in similar builds.
Thanks in advance for sharing your experience.
