What CMU blocks should I be looking at to use to construct a seating wall? The stone tops I am considering come in 12" or 14" depth typical of stair treads. An 8" thick block seems like their will be too much overhang. The tile siding will take up about 1/2" on each side. The 14" top probably makes for a better seat area.
I will also be using CMUs for the countertop. What size CMUs are best to build up the counter and what is the recommended height? Should I leave open areas underneath or block it all in?
