Using wood framing
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    #16
    Re: Using wood framing
    Most people build the oven on a concrete block stand, and then use metal studs for the enclosure and the outdoor kitchen cabinets.
    • ThisOldGarageNJ
      • 1436
      #17
      here's a little info I hope we can all find usefull..
      Cutting steel studs is more difficult than cutting lumber. You can use a chop saw or SkilSaw with a metal cutting blade, in conjunction with tin snips.
      The metal studs found at your local home improvement store will only come in the most popular dimensions. Unusual dimensions will need to be found at stores that cater to contractors. So, what you will find at your local Home Depot mainly are studs of the same dimension as wood 2x4's and in 25 gauge steel, ranging from 8 feet to 12 feet in length.
      Cutting metal studs is more hazardous than cutting wood. While many home renovators treat safety as an optional measure when cutting wood, it is certainly not optional when cutting metal. And we're not just talking about the sparks that are caused by the circular saw. Cutting metal studs by hand with tin snips is a good recipe for lacerating skin, and the sound produced by an electric saw on metal studs will produce a ringing in your ears for the next week, should you forget to wear hearing protection.
      Metal studs are not a "forgiving" material for the DIYer. The great thing about wood is that it is a very flexible, malleable, forgiving material. With metal, it's all or nothing.
      When driving a drywall screw into a wood stud, the wood practically seems to draw the screw into it. Tapping a drywall screw into a metal stud requires a bit more work and practice.
      Steel Studs - Metal Studs FAQs
      cheers
      Mark
      • Lill Dave
        • Dec 2009
        • 46
        #18
        My oven sits on 8 - 4"x6" two in each corner. Oven is almost 2000 lb , solid as a rock.
