We decided to build an open-pit style grill for our yard. We are using a space next to our oven for a few reasons... It's a good safe place for an open fire and hot coals, it was a good use of the weird little space next to the oven, and the stucco finish will make it blend into our "oven complex".
We had been researching traditional style Italian barbecues and had really liked the concept, but adding another chimney to a cooking "appliance" in our back yard just didn't suit us. We have been cooking a lot on open grills lately (an old Coleman unit and a fire pit in our patio table), and we feel just a simple open grill will suffice for our needs.
The premise of the design is to use it from the front side of the oven where we just need to lean slightly forward over the bench that runs along the front of the oven.
We began by pouring a small concrete slab to provide a level support and then dry-stacked concrete blocks. We inserted some rebar into the wet slab where the voids in the corners of the concrete blocks would go... Dry stack blocks and fill voids with concrete. We then made a form around the top and filled with concrete with rebar pieces inserted horizontally. This concrete protrusion will encompass the firebrick that will line the pit.
Here's the forms removed...
The open area in the back will serve two purposes; It will store an ash drawer and will have a louvered door in it to provide under-fire air. The angle-iron and rod structure in the next two photos support the bottom bricks. The bricks will be spaced 1/4" apart so air may "peculate"-up through and into the coal bed.
We made this rack and set in place, then leveled the entire elevation with mortar so the bricks have a level surface to rest upon. After the bottom bricks are placed, the side bricks will set in an be retained by an upper angle-iron frame that will secure them in place. This frame will stabilize the bricks and provide a means for attaching accessory items for what ever grills, stands, spacers we will eventually develop. The entire structure will get covered with stucco like the oven.
That's our plan (in motion)...We'll update soon!
The Morgans
The Morgans
