This is what I've been doing when I couldn't work on my oven, just using up the left overs. I'm completely making it up as I go along, but the idea is simply to have a place to light fires or put the coals from the oven, and grill the odd sausage. I'm a bit intimidated by the other bbq/grill discussions going here , but anyway here it is...
Pompeii Grill in Switzerland
http://www.fornobravo.com/forum/f9/p...nues-2991.htmlTags: None
Re: Pompeii Grill in Switzerland
I can't see it very well.
Does it have an opening in the middle?
How are the fires going?
Hmm, you're right, its not the clearest of pictures is it? I'll post more when I get a bit further along ...
This is just the stand for the grill. It does have a hole in the middle, which is currently covered by the beginning of the support for a concrete slab. I've got a hood and chimney for it already, so all that's missing are the bits inbetween . The only thing I know for sure so far, is that it will have a brick arch as opening, just like the one on the oven but bigger."Building a Brick oven is the most fun anyone can have by themselves." (Terry Pratchett... slightly amended)
Frances,
This is five months too late,but may be worth a thought.
We use a 20L ss pressure tank from a water supply system as a "grill/oven", both at home and when travelling. Brilliant for two.
When we build next wfo, we will most certainly build in a "Grill Pit", probably a cut-down 9kg gas bottle; maybe an old ss laundry tub.. Ultra important to have control of both air supply and exhaust. This allows temperature control comparable to electric stoves.
I shan't waste web space with details, but am happy to help off-forum.
Hope it's all good,
Jeff.
Hey Jeff, I didn't notice this here. The grill hasn't progressed any further at all, as I'm basically shut down for Winter.
But once Spring comes, and once I'm finished with the WFO (like in a year or three) I'll get back to this. What I plan to do is have a simple wood fired grill. We have such fun lighting fires in the woods and grilling saussages on them, that I decided we need to be able to do that at home. But its all a bit low tech I'm afraid.
Thanks for the input anyway!"Building a Brick oven is the most fun anyone can have by themselves." (Terry Pratchett... slightly amended)
I poured the "hearth" bit... thing, concrete slab on this today (do grills have hearths?). With the framing adhering to my favourite it'll-hold-if-you-use-enough-duct-tape school of thought. I'm a devoted deciple, in case you hadn't noticed..."Building a Brick oven is the most fun anyone can have by themselves." (Terry Pratchett... slightly amended)
My long-suffering husband was already congratulating himself on the last sack of concrete safely carried up to our house...
So then THIS happened:"Building a Brick oven is the most fun anyone can have by themselves." (Terry Pratchett... slightly amended)
...maybe I didn't use enough duct tape?
Some master builder, eh?"Building a Brick oven is the most fun anyone can have by themselves." (Terry Pratchett... slightly amended)
Did you hear the report where they tested duct tape, and basically said that it is great for about 100 different tasks? Everything except holding metal duct together, where it does a really bad job. Too funny.
Frances, do you have drawings for your grill? I would enjoy hearing how you are handling grill height, air draw for charcoal, venting, etc.
How high are you shooting for the hearth? Lower than the oven?
Etc.
Wow, that was one fast answer!
Sorry James, no plans or anything. I'm really playing it by ear and making it up as I go along. I can't seem take a mere grill seriously after building the Pompeii ... well maybe a bit more so now.
The hight is given by the number of those large lime stones that were left over from the oven stand... the inside size by a grill by a grill tray thing my twins chose last year. Its really just a project for using up the left overs...
Actually the hight does need to be considerably lower, because I'd like everybody to be able to crouch round it grilling sausages on a stick.
But I'm afraid thats as far as I've got...."Building a Brick oven is the most fun anyone can have by themselves." (Terry Pratchett... slightly amended)
My dad's list of essential tools for the home:
duct tape
2 part epoxy
WD 40
a pry bar, for things you 2 parted together you didn't mean to
and for some reason, he kept saying "a screwdriver is not a chisel".
(he actually does a lot of woodworking and boat fiddling, and has an extensive collection of tools and things, but all of the above can be found in the junk drawer at mom and dad's!)
I think we were typing at the same time.
Personally, I have to see something halfway done before I can visualize the end.
Ooohh, do I get to be brick oven merchant when I get to 2987 posts??"Building a Brick oven is the most fun anyone can have by themselves." (Terry Pratchett... slightly amended)
Well, you have to laugh! And I haven't even got a dog to blame it on..."Building a Brick oven is the most fun anyone can have by themselves." (Terry Pratchett... slightly amended)
