Commercial Grill
  • Xabia Jim
    • Dec 2006
    • 1168
    Commercial Grill
    Check out the ironwork decoration....nice ribs too!
    Re: Commercial Grill
    It's an interesting idea to use angle irons for a grill. I google translated "Costillas en addo" and it couldn't cope with "addo". Ribs on the grill, perhaps?
    • Xabia Jim
      • Dec 2006
      • 1168
      Yes, costillas are ribs.
      • gjbingham
        • Sep 2007
        • 2021
        Funny, the muscles between the ribs are called intercostals, at least in English. Probably intercostillas en Espanol. Damn! They said Latin was a dead language! I should have taken that it after all! (just kiddin', of course, dmun - I didn't catch the connection myself till XJ threw it out there)
        GJBingham
        • TDVT
          • Dec 2007
          • 57
          I imagine that it catches drippings?
          One of my other outdoor cooking endeavors is maple sugaring (wouldn't you guess there's a forum for that too?).
          I know some guys make their fire grates (for WF evaporators) that way. They say the ash caught in the angle insulates them from the coals above so they don't deform from the heat.
          • nandj1966
            • Mar 2008
            • 17
            Jim I'm still in the planning stage. (Seems to go on forever) I want to add a grill to my planned outdoor kitchen and have tried to find a large grill surface. No luck other than small sections sold at Home Depot Your post gave new insite. Thanks Do you think the angle iron would wick the heat too much? My plans are for a 24" X 36" grill surface.
            • PizzaJNKY
              • Mar 2008
              • 159
              Dmun, this one had me stumped as well. The best guess I could come up with is that the sign really say's "Costillas en adobo" but the writing is a little sloppy. I think adobo is a spice or marinade, but not too sure. I've never had it.
              "Pizza, the world's most perfect food."
              • Jaroslavgreen
                • May 2008
                • 3
                I did grill using some iron lists 4-5 mm and welding equipment! It works fine no problems!
                wood chips
                • Chediego
                  • Sep 2012
                  • 1
                  "Costillas en adobo" (not addo) means marinated ribs. Adobo is a thick sauce or glaze or marinade you either soak them in or apply while on the grill.
                  • C5dad
                    • Oct 2005
                    • 422
                    HD and Lowes are really expensive for metals - check out your local steel supplier for prices that are at least 1/2 you see at the big box. Reason is that they do not turn the metal over quickly and it is more of a favor. You should be able to find any size stock you need (round bar, wire, angle ...) Most of the folks I know use steel walkway grating or expanded and rolled/flattened mesh with a frame of angle, all mild steel.)
                    Best of luck!
                    Follow my build Chris' WFO
