Hey guys I've finally managed to finish my oven. I cured it for about a week before adding the dome insulation etc and after adding a few inches of high grade bloody expensive ceramic fibre blanket and rendering the dome I decided to fire it up.
I built a fairly decent sized fire in the centre of the oven which I pushed to the side after about an hour and a half probaby using about 5 or so big (ish) logs in the process but after all that my wall temp was about 350c and my floor temp was a rather poor 180c at best
. I do have a sufficent 4" of perlite insulation under the floor and I'm using nice thick storage heater bricks for the floor (which I researched and should be fine!)
Where am I going wrong here? Should I try it with a monster fire? Or just feed it for longer? Check out my pics.
Cheers guys!
Cheers guys!
