New guy with smoke and heat question...
  • NYC
    Re: New guy with smoke and heat question...
    So I went to my local masonry yard and they have o e type of firebrick and it is 8.5" long, not 9. They also have no idea on what grade it is. What's the best way to ensure I'm getting medium duty like the plans call for?
  • NYC
    I believe it is 45 deep by 50 wide currently.
  • lwood
    We need the dimensions of your concrete slab under the existing oven.
  • DrakeRemoray
    If you insulate with blanket, you can have a narower insulation (vermiculite you need 4", blanket 2" max). I enclosed my oven in metal studs and concrete board and in some places the oven comes within 2" of the concrete board. If I had vermiculite insulation, that would not be prudent...
    As to cantilevering, I just looked at your picutres again, and I don't see where you would be able to hang a new slab over the edge of your existing stand at all, assuming that post is important...
    If you installed a prefab refractory oven from Forno Bravo, you can save some space as well, they have much thinner walls than firebrick, but heat up faster and also retain heat (probably don't retain as much heat as a firebrick oven though...)
    How big is your hearth stand area by the way? Assuming you took the existing oven off, how much room do you have on the stand?
  • NYC
    Can you elaborate what you mean?
  • DrakeRemoray
    You really can do it yourself. You can maximize stand space by using insulating blanket, you could also pour a cantilevered hearth over your existing stand...
  • NYC
    By the way, I have been on dozens of various forums over the last 10 years (not pizza oven) and I must say you guys are awesome. The level of knowledge and sense of community here is great. Kudos to the crew and members.
  • chidding
    I'm a software engineer who's building and DYI experience amounted to building around 10 computers..
    Trust me on this one, if i can build it.. anyone should be able to.
  • NYC
    How long start to finish on average? Few full days?
  • brickie in oz
    Most ppl who build them are weekend DIY warriors and do it all themselves.
  • NYC
    My biggest issue is dismantling the existing oven and enlarging the stand to accommodate the flue landing for a 36" Pompeii. I read the 70+ pages of the plans. Is this a DYI for someone who is very handy (built a few bathrooms from scratch) or would you recommend a mason?
  • lwood
    If you can, buy a FB oven and it's basically all done for you. You already have the stand.
  • GianniFocaccia
    As a worse case scenario, if I decide to remove the oven and have a Pompeii style built, where would I get the plans to give my mason?
    Electing to remedy your situation with a Pompeii oven is not a worse case scenario, IMHO. I would call it a best case scenario.
  • brickie in oz
    You can download the for free here
    eBooks & CD ROMs :: Forno Bravo Store
  • NYC
