Re: New guy with smoke and heat question...
Update: a week ago a local fireplace expert came by. He took measurements and calculated things. Today he called me and said he would like to remove the entire flue, enlarge the opening to accommodate an 8" steel flue and install a damper system to allow control of the draft. He also wants to cut a sliding door into the steel door for the front to allow for the door to be placed on and control the air flow in. He said with controlling the air in and out I will be able to tweak it for proper drafting and retain heat as needed.
Thoughts?
Thoughts?
