Flue damper in action.
  • Flue damper in action.
    Here is a vid of my flue damper in action in my barrel oven with a fire in it.
    The temp rise is significant as the damper is closed, when the damper is opened the temp drop is also great.
    The insulated door is partially open to allow for some air flow, as is the damper.
    YouTube - ‪DSCN0825.MOV‬‏
    My Build.
    Books.
    Re: Flue damper in action.
    Cool. Is that the ocean in the background noise?
    My oven (for now):
    http://www.fornobravo.com/forum/f43/...ven-14269.html
      With your door partially open there is cool airflow around your thermometer. I get a similar effect with an oven thermometer placed in the middle of the oven if the door has been out for for a while. The temp climbs up as the oven heats the cold air. I usually wait 10 mins after closing the door before opening it again to check the reading.If you read your temp with an IR i'm sure you would get a different story. Notice your gauge reads in F rather than C
        Its the fire..
        My Build.
        Books.
          It was the cheapest I could get, I didnt want to pay $100 or more for one, this one cost $13 plus postage.
          My Build.
          Books.
            I think your thermometer looks great! It looks a lot like mine.
            Should have mine in the door within the week.
            Lee B.
            DFW area, Texas, USA
              I was wondering how it was all going, your oven looks great BTW.
              Are you going to roof over the oven?
              My Build.
              Books.
                Yes, the oven will be under a patio cover. We should start that in the next week or ten days.
                Lee B.
