The poll to divide a pizza community.
  • The poll to divide a pizza community.
    The poll to divide a pizza oven community.
    To build on the hearth, or not to build on the hearth, this the question?
    Oven was built on the hearth, it cracked?
    Oven was built on the insulation, with the hearth cut inside, it cracked?
    3
    Oven was the oven built on the hearth, it cracked?
    66.67%
    2
    Oven was the oven built on the insulation, with the hearth cut inside, it cracked?
    33.33%
    1
    Re: The poll to divide a pizza community.
    Mine are cast so I think they probably don't count.
      My Pompeii dome was built on the vermiculite cement with the hearth bricks cut inside to fit, the oven didn't/hasn't cracked but the render over the superwool insulation has small cracks through it.
      Not the choice to tick Brickie!
      Neill’s Pompeiii #1
      Neill’s kitchen underway
        Gudday
        as a tinker I want a soldier or sailor !
        Regards Dave
          Originally posted by wotavidone
          all ovens crack.
          Mine didnt.
            Mine didnt.
            There's cracks and there are cracks
            Superficial or hairline
            Larger than a few mm or an eigth of inch
            Internal or external (eg. arch or render coat.)
            so you have none of the above?
            Damon
            Build #1
            Build #2 (Current)
              I have had the magnifying glass out but I cant see any.
                oh ok, I now have slide my rating of you up a few more pegs
                Good work
                Damon
                Build #1
                Build #2 (Current)
                  I didnt use mortar, which I suspect expands at a different rate to firebrick.
                  I used a propriety made air set fire glue, its used in refractory work inside boilers and such so must endure lots of abuse.
                  My joints as Ive said before are less than .5 of a millimetre in thinness.
                    The render isnt the oven.....
                      Gudday
                      I built on a ply form brick on brick, mortar in the back of each brick .No bricks cracked no mortar to show cracks in the dome. Hairline crack between dome and entrance brickwork larger crack between rear of brick chimney and render.
                      All soldier present and accounted for including the two drunk bastards in the back right hand corner( I might have had somthing to do with that.
                      Do I pass or do I have to wait 2000yrs for the next inspection?
                        You might have called this The Cracked Oven Poll. The accuracy in cutting bricks may have the second greatest effect on whether an oven cracks. It is just my opinion but settling of foundations & uneven curing may be the main culprits. I was guilty of some sloppy brick-cutting but had a fantastically stable and level foundation that did not settle, as well as hot, dry conditions during construction and curing. No cracks in the dome or arch but noticed hairline cracks where the render covers the arch - I think there was some movement during the firings, sometime in the past year. I used my oven 187 times between 03/2012 and 03/2013. I did not repair these hairline cracks( just resealed w/ acrylic sealer) but I may eventually have to cut the render off and make a real repair.
                          Where is the option of "no, my oven didn't crack"? Not that I can see anyway...
                            I was going to have a "crack" at this poll but I moved house before my last oven cracked..
                            ....then again that oven was "violated" rather than cracked.......and so would you if you sat on a hot bed of sand and concrete
                            Finding it hard to be serious with this one.....
                            Damon
                            Build #1
                            Build #2 (Current)
