Is it too cold to fire?
  • fornax hominus
    • May 2009
    • 157
    you don't give up on your oven just because it will freeze the bits off a brass monkey .
    Here are a few tips from the ''Valley '' where it's a balmy -13c ..nothing compared to the -30c we will get in january.
    First, if you have not fired up for a week it is going to be cold in the oven . To avoid thermal shock on the ceramic refractories you need a warm up fire .
    I build a small fire [ 3 pc.s of wood ] and let it burn for 45 mins or until the inside row2 bricks feel warmish.
    A thing to note is that when air gets cold it compresses , this means that the air entering your oven has a higher percentage of oxygen than in warm weather . You now have a balancing act , the fire will burn hotter , but at the same time you have more cold air lowering your temperature gain.
    In cold weather I will place one brick against either side of the door reducing the opening . You don't need as much combustion air as it is ''richer'' .
    In really cold weather I will stand a brick on the entry floor directly in front of the door but leaving a 4-5 inch space . As this brick warms up [and will it ever ] the incoming air hitting it will be ameliorated and baffled down a bit. I will also drag hot coals to the front of the oven to warm up the incoming air entering low in the oven .
    I draw the line at about -25c .. too hard on the cook .. freezing in back and roasting in front ..
    Hey in one month the days start getting longer!
  • jeeppiper
    • Mar 2011
    • 321
    Re: Is it too cold to fire?
    Words of wisdom!!! Thanks for sharing.
    Personally, I think the best time to use the oven is when it is butt-cold out on a clear sunny day. It warms the soul.
    • Laurentius
      • Nov 2010
      • 923
      The best time to fire up the oven is when you have something to cook, unless you`re like me and just want to play with fire. (in a safe environment)
      • Greenman
        • Feb 2013
        • 1123
        It is only after reading posts like this and watching some of the recent news footage of the snowfalls in parts of North America that I appreciate the balmy weather that this part of the globe provides.
        Last winter the minimum overnight temp was about 4 degrees C and the middle of summer gets to about 38 C on the hottest day. It will be summer here in a week or so and today is 33 C.
        Just lucky to live in a free country with a climate that is conducive to living outdoors much of the time I guess.
        Cheers ......... Steve
        • fornax hominus
          • May 2009
          • 157
          Well some of the advantages of cold weather are ,.
          a. no mosquitoes biting the back of your legs ,.
          b. snow is handy to cool off your pan of roasted coffee beans.
          c. when you put in loaves of bread you can grab some snow and pop it in an empty pan and it will steam and give the bread it's oven '' spring''..
          This is all fine and good , but ask me again when I have had to dig a path to the oven through a metre of snow.
          • fornax hominus
            • May 2009
            • 157
            Laurentius
            I think with 3 wood stoves, the wood oven, wood fired grill, and a wood fired maple syrup evaporator ..I am in your play with fire club [and have the scars to prove it ].
            tim
            • GianniFocaccia
              • Jun 2009
              • 1645
              Hmmmmm... Kinda like going out to start the oven, and after watching the fire for awhile, run into the house to find something to cook!
              • Greenman
                • Feb 2013
                • 1123
                I think that there is a lot more members of the 'Flickering Fire Appreciation Society' out there than will own up. There is a certain comforting aspect to contained fire.
                • Tonyp
                  • Jan 2009
                  • 165
                  As for that whole cold and snow thing.. well I am about 80 miles South of Fornax Hominus and right smack in the middle of where the lake snow likes to fly..We didn't get hit that bad like Western NY but we did get a couple feet.
                  Our seasons are messed up here. There is early Winter, Winter, late Winter, and then Spring which lasts about 2 weeks and then Summer for about 2 months before we have Fall for 2 weeks before it's back to early Winter. Now you know why I put my WFO indoors in the kitchen!
                  Today I was going through the grocery store and thinking, now what can I put in the oven tonight? Ended up with some hot dogs to stick on the campfire forks to cook over the indoor camp fire! Fun stuff!
                  Tony
                  Link to my oven build thread:
                  40 inch indoor pompeii in NNY
