so i returned from japan yesterday, and though my brain was still 16 hours ahead in tokyo and i hadn't slept a wink, i had to fire the oven up for the first time.
i started with a small fire, though it has been sitting in the sun for three weeks. it doesn't seem like there was any moisture to drive out---no steam from the mortar at all. however, cracks did open up in several places, like other people have described, seemingly from wherever the mortar had time to sit and dry up for a bit before the next course went up. the cracks are small, but when firing it this morning, they were smoking a bit until the fire was large enough to draw properly out of the opening. i checked, and from the smell it was definitely smoke and not steam. the plan is to wait until they are open fully again, then squirt some refractive putty insulation in the cracks, then float another layer of mortar over the whole thing.
does this seem like a sensible plan of action anyone?
it didn't seem to heat up anymore at the point of the cracks than the rest of the dome did (i used the infrared gun). the entire dome got about 150-200deg.F, hottest at the top. the inside of the dome reached about 500 deg. max, but really was probably stable at about 350deg. without the flame licking the surface. today i will go for a slightly hotter fire.
