My supplier was telling me for the castable product I bought from him likes to be cured at about 175 degrees for 8 FULL HOURS. I was planning to go with a 7 day cure staging as described in out insruction manual from this site so wondering how this suggestion from my supplier will fit into what is normally done by oven builders on this site. I could do 100 degress the first day and then 175 the next but let it burn at this temp for 8 hours and then progress onto the 300 degree etc stages. So not real sure how to treat this castable part of my oven, if I burn a long time at 175 degress not sure if that is a no no or not.
Also I plan to put my blanket insulation on after first cure so I can see cracks etc so if I understand it right if I do this I will be putting my vermiculite concrete over top of blanket and then I will need to also let the sit for a week and then cure it also. Would the curing of the vermic layer need the full week before the cure and then then slow methodical heat up times over small increments or how would this second vermic layer need to be cured....thanks wayne
