Curing strategy
  • Acoma
    Re: Curing strategy
    KISSSSSSSSSSSSSS. Ohh how sweet that was
    I am sooooo happy!
    Finished the oven at 1:30pm Saturday with a 30 minute 900-950 burn. I then go out at 7:30am this morning to check retained heat temp. Guess what? It was at 453 degrees, wow! Of course I forgot to check the floor temp, this was dome temp. Approx 65% retained heat 18 hours later due to the 700 cure day. I still have more insulation to do
  • gjbingham
    Re: Curing strategy
    Like a great wine, you also have a great finish Robert. I'm glad to hear that you're happy with the results. Embrace you're oven, give it a big kiss. (Keep your tongue in your mouth. They don't taste that good!)
  • Acoma
    Re: Curing strategy
    OK, now for my final documentation on curing. I say it is the best method until shown otherwise. Yes, I had cracks. The best thing with this method is that it allowed me to bond with the oven, and I know that sounds wierd. I mean bond by acts of knowledge. I can now use the wood in a constructive manner to heat up the oven, maintain heat, increase, balance, and know saturation. All this during curing process. Could I have prevented cracks, I already wrote my details earlier on my thoughts regarding this. Would I build another oven, YES! I will likely build a smaller version for my in-laws from ACOMA. Life is short and special, so try it, love it, soak it in. This was a special moment in my project life that allowed me to do something I thought I could not do. I did this all myself. Oh ya, this is about curing. Wrap yourself around this new method, it will help so much.
    The end!
  • Acoma
    Re: Curing strategy
    As I have cured my oven, the drop in temperature from the previous night is not great. How do you answer this into the maintains heat concerns? Is going down 40% in heat overnight that significant, i.e. 600 cure yesterday, to waking up and starting with 397 degrees? I agree that it would likely be best to maintain a heat to drive out the moisture, but that will be the next generation, correct? I believe we are on the right path. If we do not have the heat maintained, which would have to be wood free, then we have the next beth method right now.
    Re: Curing strategy
    The recommended cure rate for castable refractory (which is the same material essentially, as fire brick or refractory mortar),is (for our WFO wall thickness) 50 C/hr I .believe that this is a good guide for a curing stategy. Simple enough
  • Xabia Jim
    Crack science
    Originally posted by Xabia Jim View Post
    David, but I could be bass ackwards,
    From my days making ceramics and pottery I remember that bisqueware is usually dry. As I recall wet bisquit will surely crack. Neat analogy to WFO's
    Thinking about this further, bisque firing was done at lower temperatures, then the clay was glazed and fired at higher temperatures. Bigger items have more of a tendency to crack than smaller ones.
    From my days as a Geologist I learned that clays were 40% air space (sand is more like 25%) so in drying a clay, it takes a long time because it's comprised of tiny microscopic plates all jumbled up.....drying clay shrinks and cracks but potters are able to make crack free clay vessels.
    We cycle our ovens during curing, but could a steady increase in heat be even better?.......searching for the VMO
    Re: Curing strategy
    Inishta,
    Heartily agree. I don't think it is possible to eliminate fine cracks entirely. Theyre there and the open abit when firing but they disappear when the oven cools and they dont seem to get any worse. So what ? What would you expect when the whole structure expands so much. It doesn't affect the performance. All ovens and kilns for that matter have cracks. In fact that is precisely why the ovens are made of bricks so the cracks can occur at the joins where you want them to.
  • Inishta
    Re: Curing strategy
    David..........I can see where you are coming from with this. It would make sense to initially go up to cooking temps more slowly and therefore limit rapid expansion. Unfortunately most are not going to be maintaining fire in the oven so the heat/cool cycle must continue. Members have reported improved performance many firings after the curing period. Clearly driving out moisture continues quite some time. I don't feel that a lot of the cracks we are seeing are avoidable given expansion coefficients but neither are they detrimental to performance of the oven nor in most cases appearance, IMHO.
    Someone once said ........"perfection is a journey, not a destination". Long may we all share it.
  • Acoma
    Re: Curing strategy
    Now, to the new technique recently updated, and practiced. I believe that after the 4th cure, at 600 temp day, for 10 hour sessions, totaling 40 hours into the curing process, that I may (or may not) have answers to help others for crack prevention. This also applies to the building process, which leads to the curing cracks that I believe are impacting me.
    I thought I had a disaster on my hands when I saw the spider web of cracks on the outside dome, and the 3 cracks along my arch, one on each side, and one up top. I believe my approach to building the oven was careful, with consistant mortaring of bricks, using patience and practice. I thought that by just applying a thin amount of mortar to the outside dome (1/4 to 1/2 inch) it might help the bricks to limit movement. I did not mortar or add support to the outside of the arch sides. For the dome, the bricks all crossed bricks below with middle point positioning. I believe that the Refmix mortar I used was well worth the cost, it did not break up or crumble meaning that heat in the area was right for the environment during the COLD and snowy winter, and no bricks are cracking. What I did by packing each bricks sides, keeping the bricks moist, then moving to the next brick allowed strong bonding between brick and mortar. The weight of the dome is also great and limits movement due to pattern of bricks laying upon each other with great balance. I built my arch with the idea of having an angle for looks, but I also attempted the best way to keep strength as well.
    Now for the cracks, I look at where the cracks are and believe I may know the answer.
    A: Dome cracks are only showing on the outside, not on the inside. I believe that due to the shell of mortar and expansion, that it was a waiste at this time, but after the curing process would be possible. The bricks were well mortared together and needed to bond with moisture being driven out. No cracks are going into the dome, none are going through bricks. I believe I would have none, or fewer crack concerns upon exterior of dome if I would have waited with this detail.
    B: The arch has cracks along the wall which I believe is because of limited weight with no true mass of supporting bricks above. Looking at the dome, lots of weight is balanced by brick upon brick, altered upon each other. My cracks on the sides occur after the 3rd brick up which prepare for the arch to meet the wall. There is no real weight at the front face area either, just one brick above.
    C: The arch at the top center is also full of exposure with no support above or on the sides.
    D: For the arch, so much is expose to the cool outside compared to the dome, and the heat measurement at the arch is approximately 30 percent of dome temp. To me, this is where the root issue is to be answered.
    When dealing with heat expansion from within the oven for 10 hours plus at 300, 350, no issues occured to the dome or arch. Upon entering the 500 temp, the heat finally reached the outside dome and arch enough to allow varing heat to create the varying expansion of bricks while the mortar cured. Being that they have different heat affecting the cure, I believe that seperation of bricks and mortar resulted. I also believe that if I did a rectangular arch, My issue may have been prevented as well. The curves of the arch seem to expose curing differences and weight balances during the cure, that I believe were the cause of the cracks. Now, this is a new practice, and I am merely documenting the details. Am I wrong, who knows, I am not a mason, I have only built one oven.
    Tomorrow is day 5 with 10 hours of 700 temp. I may or may not have further issue with cracks. I may or may not have cracks on the inside of the dome.
    Once the curing process is done, I will then go into the plasma state where my oven will once again be tested with a new dimension of heat. I may go up to 900 for a couple hours for a few sessions, and do some foods. This will not be long hour curing temps, just heat temps. After a few sessions, I will then go to Plasma state and saturate the bricks to allow for pizza. I will likely do my first pizzas on Sunday, April 13th. Saturday is wood day.
    I can only hope this detail helps someone?
  • Acoma
    Re: Curing strategy
    David, I don't believe you are being questioned. I believe we are evolving with techniques best fit to drive out the moisture, eliminate or minimize cracks, and strenghten the oven with best practice. The old philosophy for ovens was updated recently upon world practices. Should this method you speak of be a new and evolving technique to revolutionize the curing process, then that is AWESOME! My idea is for you to apply this practice you speak of to an oven you plan to build, even a guiny pig mini oven, does not matter. If it works with no cracks, then wala...
    Re: Curing strategy
    My point about the biscuitware analogy was that although it may appear dry there is still water in it and that takes energy to remove it, which is still being eliminated well over waters boiling point of 100 C . Why would you want to deliberately make the material expand and contract at this delicate stage? It doesn't make sense. Just a gradual expansion is a better way. Castable refractory firing schedules suggest a very slow and steady increase. Theyre the manufacturers so they should know their product.
  • Inishta
    Re: Curing strategy
    But it's the Italians that started this new cure recommencation 3 months ago!
    Precisely.............I read James first post on this thread as the Italians putting FB users right on curing ovens...........something that I was never informed about when we built our oven. Thank goodness I found FB forum.
  • Acoma
    Re: Curing strategy
    Well, I have lots of cracks along outside perimeter, marathon types. Long distance, perimeter distances, and all shooting to the top. 4-5 of them. I have a 1/4 to 1/2 inch mortar as shell, not helping, but the cracks don't run to the inside, just to the mortar within bricks on outside of dome. I cannot see any cracks on the inside though. I cannot verify this part because the inside is as black as a coal miners face. I am proceeding with the curing strategy, and I will use furnace cement with some grinding once the curing process is complete.
  • Xabia Jim
    Re: Curing strategy
    David, where I'm coming from is thinking about the full range of the heating and cooling cycle as it relates to the thermal expansion and contraction. By cooling to ambient, you get a broader range of expansion during the cure. Since you will do this many times over the life of the oven, I'd think that would be good....but I could be bass ackwards, maybe it's better to do that after you've driven out the moisture.
    Re: Curing strategy
    Potters fire their kilns for a biscuit firing (unfired clay) at 100 C/hr so the kiln and the wares are not too stressed. We go much faster than this with our WFO's so the initial curing should be much slower. Mechanical water is eliminated up to 300C but chemical water is not fully eliminated until around 500 C which explains why you go through so much fuel when curing and why the oven continues to improve in performance after susequent firings. Hope this helps.
