Doing the top down
  • Doing the top down
    Thanks to JP and his post with this link.... Top down
    I tried the top down method...
    The advantages of the top-down fire building method are:
    minimal start-up smoke;
    no chance that the fire will collapse and smother itself;
    no need to open the loading door to add larger pieces once the kindling fire is established
    I will add that there was a very even burn and relatively fast.
    I started with large wood, one flat piece of paper on top to hold the small stuff, one crumple and a bunch of bits on the top...even some dry rosemary!
    I'd say a thumbs up to doing the top down....
    Re: Doing the top down
    ....where's the oven?
    sorry......it's a fire for a paella....
    probably twice as much wood as needed but it was my first time top down....
      I think you need bigger pieces at the bottom XJ. The first time is always a scary adeventure, regardless of what you are doing.
      GJBingham
        for the oven, absolutely right George...add big wood under the stack.
        but for the paella, all I want are some coals, and quickly! then I just keep the fire burning with a few sticks....
          How about a cooking vid XJ? I couldn't guess my way to paella, even though I've had it several times.
          GJBingham
            George I don't vid, yet
            Paella....it's much easier than you think and very forgiving...you just need a good soup stock and then go for it!
              NOW....how about a vid on being a stay at home dad...
              my daughter has twins, just crawling last week.....
                Hey Jim, I've been making stock since you posted your paella recipe... I haven't used any yet, but still...
                  I did a top down yesterday in the WFO - perfect. Minimal smoke and faster startup. I was really surprised at how well is caught on.
                    Doing the top down method right now. It is so much better than starting with sticks, then moving to logs. I love this, and now, I need to perfect it
                    Acoma's Tuscan:
