Hairline cracks inside cob oven
  • mtra0001
    • Jun 2020
    • 4
    Hi guys, I cured my brand new cob oven for the past 6 days. Today I decided to try and burn off the black carbon inside my dome but noticed some long hairline cracks running inside the dome as shown in the enclosed images. I decided to hold fire as I wasn’t sure whether further increasing the temperature would create further issues. Do you believe there is cause for concern?
    You don’t say how long you left your oven to dry between completing it and the first fire. But, as a rule of thumb, depending on air temperature, movement and humidity, it takes around a week per inch of thickness to dry sculptural clay work and a cob oven much the same. Even when dry the firing must proceed slowly or cracking and at worst steam spalling result.
    • mtra0001
      • Jun 2020
      • 4
      I let it dry out for almost 3 weeks. I suspect the last fire was a bit on edge and led to most of these cracks. Like I said they are very narrow cracks and will probably try to patch them up after I clean out the black carbon.
