Birch vs Ash
  • Purple House
    • Jan 2020
    • 4
    Birch vs Ash
    Have recently starting using birch in my commercial oven. Have been noticing that the bottoms of pizza are blackening often wondering if this has anything to do with new wood and the possible residue? We are mopping oven floor every so often.. other possible reason could be to much semolina on oven floor?
  • RandyJ
    • May 2010
    • 1191
    As far as i know as long as you are not using soft wood then wood is wood. One mAy burn hotter than the other. Have you been checking your temperature making sure it is not to hot.
    • hughjamton
      • Jul 2010
      • 64
      The Firewood Poem
      Beechwood fires are bright and clear
      If the logs are kept a year,
      Chestnut’s only good they say,
      If for logs ’tis laid away.
      Make a fire of Elder tree,
      Death within your house will be;
      But ash new or ash old,
      Is fit for a queen with crown of gold.
      Birch and fir logs burn too fast
      Blaze up bright and do not last,
      it is by the Irish said
      Hawthorn bakes the sweetest bread.
      Elm wood burns like churchyard mould,
      E’en the very flames are cold
      But ash green or ash brown
      Is fit for a queen with golden crown
      Poplar gives a bitter smoke,
      Fills your eyes and makes you choke,
      Apple wood will scent your room
      Pear wood smells like flowers in bloom
      Oaken logs, if dry and old
      keep away the winter’s cold
      But ash wet or ash dry
      a king shall warm his slippers by.
