Finishing up my 36" build and had 3 curing fires with the insulation on. Got up to 300 degrees. Had a nice day yesterday and slapped on the scratch coat. Then last night it dawned me i prolly should have finished the curing process before rendering. I confirmed that on this priceless forum. Apparently one cant research enough. So now do i finish the curing process, finish the rendering, or both? 4" of ceramic blanket so it shouldnt cook the render too much. Thoughts?
Cart ahead of horse
The "cure before render" is a recommendation not a rule. Just go slow on the curing fires. Lay a piece of clear plastic loosely over your vent occasionally to check for escaping moisture. It's amazing how much moisture is contained in a new build, especially when an insulating concrete (perlcrete or vermicrete) is incorporated...or a lot of mortar has been used to fill in dome brick gaps. Go extra slow and do some baked small potatoes in a Dutch oven or beans or a batch of ribs with long, slow & low temp cooking. Those 300-400F temps are perfect for a lot of good eats.
Roseburg, Oregon
Blog: http://thetravelingloafer.blogspot.com/👍 1Comment
Heed Mike's advice, this is where we see builders get too excited and fire too fast and hot and potentially damage the oven or outer coatings.Comment
