Hi all, I've been reading tons of information on curing a masonry oven once completed. Seems to be an overwhelming amount of information out there which is making me more confused. So upon completing the build, what's the next step? I'm guessing waiting one week even before burning a few newspapers is most definitely required. So after that, starting the first "real" fire, is the idea to get each and every firebrick to a low temp {say for sake of argument 100 degrees farenheit}. OR is the idea to get the overall oven heat from the fire to 100 degrees, and for how long?
my other question is rain. Suppose your oven is fully cured of moisture, you've gone through the step by step process now your done curing. then it rains on your oven. Do you have to go through the curing steps all over again?
