Crack in oven floor?
  • RyH
    • Apr 2008
    • 30
    I have just noticed a small crack running through one of my four floor sections in my oven. I have had over 10 fires on top of the intial curing fires.
    Is this serious, I have a good layer of vermiculite underneath so should not loose heat?
    Any suggestions?
    sigpic
  • Frances
    • Aug 2007
    • 2186
    Re: Crack in oven floor?
    I think you should be fine. Cracks in the dome can be a problem for structural reasons, but the floor is ok... so long as you don't catch the peel on it.
    At least that's what I would think. Any other opinions out there?
    • james
      Brick Oven Merchant
      • Mar 2005
      • 4648
      That sounds right to me. Typically, floor cracks don't get larger very fast and you can grind a small lip -- if one develops.
      You should be fine.
      • SpringJim
        • Apr 2008
        • 562
        assuming the hearth has reinforcement, it should be fine.
        cracks, everybody's got em....
        • RyH
          • Apr 2008
          • 30
          Thanks for the advice, I thought it would be OK but when you see it for the first time panic sets in.
          Luckily the crack runs vertical so should be no issue with the peel.
          Thanks again
          Ryh
          sigpic
          • james
            Brick Oven Merchant
            • Mar 2005
            • 4648
            Keep an eye on it (not that you couldn't), and let us know what it does.
