It seems that the insulation board (Super-Isol) under my oven is saturated with water.
I believe it happened when I was forced (by the weather) to cover the oven with a tarp while it was still fairly hot. I am on day #7 in the oven curing process, and the day in question was the day I installed my insulation blanket over the dome (so it retained a lot of heat and moisture under that tarp). I know it's wet because some water is seeping thru a thermocouple hole in the middle of my hearth. It might not all be saturated, but some of it is.
So, what now? Do I proceed as normal and keep curing? Today I'd expect to go up to 700 degrees or so. This week is supposed to be sunny and in the 70's, so no cover needed. Will it just dry out with the heat, or is there some danger to firing it when the insulation is so wet?
I believe it happened when I was forced (by the weather) to cover the oven with a tarp while it was still fairly hot. I am on day #7 in the oven curing process, and the day in question was the day I installed my insulation blanket over the dome (so it retained a lot of heat and moisture under that tarp). I know it's wet because some water is seeping thru a thermocouple hole in the middle of my hearth. It might not all be saturated, but some of it is.So, what now? Do I proceed as normal and keep curing? Today I'd expect to go up to 700 degrees or so. This week is supposed to be sunny and in the 70's, so no cover needed. Will it just dry out with the heat, or is there some danger to firing it when the insulation is so wet?
