Cedar Fire Wood
  • slbrickman
    • Oct 2008
    • 6
    Cedar Fire Wood
    Oak does not seem to be working for me when firing up my oven. I think I need a wood that burns fast for the initial firing then switch to oak once the oven has soaked enough heat.
    Cedar is easy to get in Texas. (It is considered a pest in West Texas). It seems to burn easily and has a very bright flame.
    Has anyone had any experience with cedar for firing an oven?
  • Rastys
    • Feb 2009
    • 118
    Re: Cedar Fire Wood
    I had a load of used western red cedar timber panelling salvaged from work many years ago. I kept it for a host of uses but ended up using it mainly for kindling wood in the oven.
    Great, straight grained, easy to cut and burned beautifully with a good fire in minutes. I wish I had more.
    Oak is an expensive wood out here but we have heaps of eucalypt (gum) which make great hot fires heating a well made Pompeii in around an hour.
    Rastys
    If you don't succeed the first time, try again and again until you get it right!
      Re: Cedar Fire Wood
      If oak isn't working for you, it's either because it's not dry enough (is it brown on the ends, with radial cracks?) or it's not split finely enough.
      Don't hesitate to start your fire with softwood, even construction scraps, but hardwood is best for cooking: it has less tendency to pop and spit.
      • texassourdough
        • Nov 2006
        • 1719
        Re: Cedar Fire Wood
        I use Mountain Cedar all the time for heating the oven from my neverending supply around my house. From other reading cedar is a preferred wood in the Middle East for heating wood ovens for it burns fast and hot. The biggest "problem" is that it has a lot of aromatics in it that cause it to smoke and create a slightly strange smoke. However this is no problem in a bread oven for you will be burning the oven to a clear state (about 750 where organics burn anyway so there are no wierd aromatics or smoke.)
        Pizza is a bit more complicated. As you suggest, once I shovel out the excess coals and clear the cooking area I switch to oak. However, it really isn't a big deal though there are two considerations. One: a new cedar log will often smoke but the smoke will never get near the pizza for the fresh air feeding the fire is coming in over the hearth and the smoke will be going out the top half of the oven portal. The other issue is that the cedar will occasionally pop and send sparks out into the oven and onto the pizza - which is a good reason to make sure any cedar you put in after you are cooking is DRY. The cedar coals seem to be no problem - they are pretty much like low density charcoal. Biggest limitation is they burn faster than oak or mesquite so when doing lots of pies, the harder woods are better for you won't have to manage the oven as much.
        Hope this helps!
        Jay
        • slbrickman
          • Oct 2008
          • 6
          Re: Cedar Fire Wood
          Do you think cedar generates enough smoke to be a nusiance to my neighbors? I have a typical back yard in the middle of a typical Texas subdivision.
          But when I think of it I created a heck of a lot of smoke trying to burn oak that apparently was not all that dry. Perhaps a very good cedar fire will not generate as much smoke as poor burning oak.
          Do you know of any ranch owners near San Antonio that would be happy to allow me to clear some cedar off of their land?
          • slbrickman
            • Oct 2008
            • 6
            Re: Cedar Fire Wood
            I have some scrap cedar lumber. I will try it out. Want to see if it makes a lot of smoke.
            • Jed
              • Apr 2008
              • 428
              Re: Cedar Fire Wood
              slbrickman,
              We don't have access to much in the way of hard wood here in Central Oregon. Mostly pine and juniper... pretty soft woods.
              My opinion is that any wood will heat the oven. (really, any thing that will burn will heat the oven)
              If the wood isn't cured, no matter what kind, it won't do a very good job of heating the oven - burn poorly and make a bunch of ugly smoke.
              I don't know if this is a fact, but as a rule in my mind I assume that wood will have about the same amount of btu's by weight. Oak is heavy and dense and will have more btu's than the same volume of cedar. The heavier the cured wood, the less you need to use to get the same amount of heat.
              Oak should work great. I would love to have access to the oak (or any hardwood for that matter). If it isn't working for you, probably not cured well enough yet. It can also help, as Dmum suggests, to use smaller diameter pieces of wood, they tend to burn faster than big chunks.
              At the end of the day, your objective is to get the btu's out of the wood and into the masonry. And a hot fire is the best tool for the job.
              How new is your oven? Is the masonry fully cured?
              JED
              • texassourdough
                • Nov 2006
                • 1719
                Re: Cedar Fire Wood
                Hi Brickman!!
                I live on a couple of acres so smoke is not a big deal. The bark tends to smoke more than the wood so peeling cedar logs would be helpful but the bark is oily and is good fire starter. NOTE: I load my oven with everything from dead twigs with red, dry needles to smaller twigs to big pieces when I load the oven. The needles burn so well the fire is almost always a one match fire. I think the needles smoke the most - particularly if they are a bit green or wet so you may want to avoid them!
                WRT a regular subdivision...the smoke is worst early on. But it isn't IMO all that much worse than a BBQ with a fire box... which is SUPPOSED to make smoke (well at least some). The worst smoke is usually over in fifteen minutes or so so it isn't forever. As the oven heats the combustion of smoke and stuff gets pretty complete!
                Oak gets smoky if it gets fungal rot and a lot of our oak has that problem (at least mine does).
                I think the answer may lie in giving it a try and IF you have complaints give them a loaf of bread or invite them over for a pizza!
                Oh...Jed makes a really good point. Wood is pretty consistent in BTU per pound. The biggest disadvantage of cedar is it is pretty light and therefore you need more of it... but it's free around San Antonio!
                Good luck!
                Jay
                • Wiley
                  • Mar 2008
                  • 804
                  Re: Cedar Fire Wood
                  This will probably open a can of worms as some people strongly dissagree with this practice, but it works for me. When I'm thru cooking pizza for the evening I shovel out the coals and load the oven with wood for the next firing. The residual heat dries the wood so that it will ignite easily and burn with less smoke for the next firing. Leave your WFO open so that the moisture has a way of escaping rather than shutting it up tight.
                  Also if the coals I'm shoveling out are of significant size, I drop them into a bucket of water and once the fire is extinguished ladle them out. They are essentially charcoal and work well to add to a small fire that one keeps along side the cooking area when roasting. They give good heat and not alot of smoke.
                  Bests,
                  Wiley
                    Re: Cedar Fire Wood
                    This is a good plan: Don't forget the leave-it-open part, heated wood gives off volatile gases, as in this charcoal retort, which are flammable.
                    As for making coals into charcoal, you only need a tight fitted lid on a metal garbage can: The fire will burn out, and you won't need to dry out the wet coals.
                    • Wiley
                      • Mar 2008
                      • 804
                      Re: Cedar Fire Wood
                      dmun,
                      Drying them out is not an issue as they almost instantly extinguish and float very high in the water. A moment to scoop them off (I toss them on a waiting old cookie sheet set at an angle so the clinging water can run off) and they are virtually dry and surprisingly clean to handle. Another nice aspect of doing it this way is the charcoal is black and shiny not covered with a film of ash as had it "died by suffocation" in a closed container.
                      Just a case of "different boats, different splices" :-)
                      Bests,
                      Wiley
                      • texassourdough
                        • Nov 2006
                        • 1719
                        Re: Cedar Fire Wood
                        Hey Wiley!
                        Assuming you live in WESTERN Washington - you need to dry your wood! That area is a SWAMP!
                        Here in San Antonio we have enough dry weather it isn't ususally a big problem but I do keep a trash can full of dry wood and sometimes use the oven to dry (preload like you do). A good practice but do leave the door open a bit... and best wait until it has cooled down some.
                        As dmun says, put the coals in a good trashcan and you will have DRY, good charcoal!
                        Jay
                        • slbrickman
                          • Oct 2008
                          • 6
                          Re: Cedar Fire Wood
                          I should not admit this but, out of frustration I got this great idea to dry my firewood on a gas grill! You know the rest of the story, right??
                          I have never seen flames belching from every opening of a covered grill like this before!!
                          • Wiley
                            • Mar 2008
                            • 804
                            Re: Cedar Fire Wood
                            Now Jay,
                            Even in a swamp their are some areas drier than others. I live in the rain shadow of the Olympic Mountains and the small island on which I live gets on average of 18 to 20 inches of rain. However, if one were to drive 20 miles to the south you will double that number (and have about the same rainfall as Seattle). The really wet areas are on the west side of the Olympics where many areas classify as a "rain forest" with many times the rain we get.
                            Bests,
                            Wiley
                            • texassourdough
                              • Nov 2006
                              • 1719
                              Re: Cedar Fire Wood
                              Hi Wiley!
                              I love Oregon and Washington! I fly up a couple of times a year to fish for steelhead - will be on the Grand Ronde this fall and hope to fish the Skagit next spring. With all your drizzle I just couldn't pass the comment up! Even with only 18-20 inches I assume it mainly comes in drizzle and wood piles get pretty wet (or at least damp). So I was confident wood drying was smart!
                              Be well and Bake On!
                              Jay
