Black smoke...
  • cckarman
    • Aug 2009
    • 1
    Black smoke...
    I am using my brick oven for a year now. Being a scout for over 30 years now I have the feeling that I am really capable of making a good fire. However, still at each reloading with 1 or many logs; after a few minutes a thick, black, smoke arises from my chimney. The smoke slowly dissapears after a minute or 5; to return at the next reloading.
    This clearly indicates incomplete combustion, but I am not so sure what to do about it. Should I change chimney or oven-opening sizes?
    Some pictures added below to give you a feeling of my oven.
    Cheers,
    Chris
  • PerryPizza
    • Sep 2008
    • 90
    Re: Black smoke...
    Hi Chris,
    Welcome to the forum, what kind of wood are you using?
    My rustic oven;
    http://www.fornobravo.com/forum/f8/p...oven-6770.html
    sigpic
    • Neil2
      • Oct 2006
      • 1374
      Re: Black smoke...
      It culd be the crosote burning off. Look inside before you start and you will see that the bricks are blackened. You know when you have reached high temperatures when all the black gets burned off leaving a "white" oven (actually brick coloured).
      • charlesaf3
        • Sep 2009
        • 30
        Re: Black smoke...
        my first thought was "what wood"
        second is, are you putting a door in front of the fire before its complete burned down? That would also result in incomplete combustion.
        Or maybe not enough insulation or thermal mass?
        Charles
        Here's a link to my oven pics thread http://www.fornobravo.com/forum/f21/...oker-7856.html
