Oven not getting hot enough ?
  • type2tattoo
    • Oct 2008
    • 7
    Hi My husband Matt built this oven last year, we have had a few runs at cooking pizza but up to now none have been really successful. The main problem seems to be that in order to keep the oven hot enough to cook the pizza it has to be stoked really high and it then burns the top but the bottom of the pizza doesn't cook properly.
    If the fire dies down the retained heat seems to settle at 300c any ideas where we are going wrong?
    Here's a pic
    Matt has replaced the floor with terracotta tiles which has helped to move the pizza further away from the fire but it still stays at 300c
    Would lowering the opening arch help?
    Many Thanks x
  • ThisOldGarageNJ
    • 1436
    Re: Oven not getting hot enough ?
    Go to the Forno Bravo Store and order (download) the Pompei Plans, They are free... Read thru them, We cant see alot of how you built your oven and materials etc, reading the plans will guide you and let you know the areas where you are in trouble. But your biggest answer I see,, Your chimney should be more to the front,, What if anything dod you use for insulation ? and is that Firebrick on the floor or cement ?
    One suggestion, Try running the oven with the chimney blocked off and use the door as a chimney.. May help you retain enough heat to get the temp a little higher,,
    Look thru the plans,,
    Good luck and post any other pics you have of building it,,, someone here should be able to help
    Mark
    • RTflorida
      • Jan 2007
      • 1446
      Based on the photo, I have these comments:
      1) this is a small oven, maybe 24" for the inside diameter? The entry (opening) appears to be a bit large the oven size. I know you need room to work, but it adds the heat loss. This is a problem with building a small oven, you have to scale all aspects accordingly.
      2) From the overal thickness it does not look like you have much insulation in the dome, what about under the hearth? As we tell everyone - INSULATE, INSULATE, INSULATE
      3) your flue and chimney appears to be nearly in the center of the dome, a BIG no no for getting an oven up to temp and holding that temp. Besides a lack of insulation, this is probably the greatest loss of heat. As mentioned, it needs to be positioned in the entry area, not the dome.
      Mark's suggestion to download the pompeii plans is spot on. I would compare what is recommended in the plans with what you have actually built. Good luck
      RT
      • PizzaPolice
        • Sep 2006
        • 338
        Ummm... If the oven is burning the top of your pizza and the bottom is under baked, I would consider losing the metal pan. You spend a considerable amount of time building the heat throughout the oven (two Mississippi) and then you insulate the bottom by introducing a cold metal pan between the floor and the pizza. The oven is doing its job by baking the top (exposed portion of the pizza). Hades himself could not inflict enough heat through the pan in time to evenly bake the pizza.
        Change one thing at a time. Try that and report back.
        Good luck.
        • RTflorida
          • Jan 2007
          • 1446
          PP, good catch. I guess some of us tend to instantly lean towards the construction side.
          I've never considered using a pan for pizza in my oven...guess I tend to ignore references to it.
          RT
          • type2tattoo
            • Oct 2008
            • 7
            Thanks for the replies peeps we have removed the chimney and put it nearer the front and made the hole smaller, just going to cure it now, will let you know
            Many Thanks and lets hope it works we have a pizza party tomorrow for my yo9ungest lads 18th
            • ThisOldGarageNJ
              • 1436
              Hey tatoo,
              I often start my pizzas in a pan and move to the brick after it firms up. It makes it easier to have 4 or 5 pizzas ready to cook and somplace to cook them when they're finished,,, I know you dont have much room, but can you stack a half brick on the sides to keep your fire going when you cook.. It will help keep the dome hotter, which helps recharge the floor more quickly.. and keep your floor covered with coals till the last minute to get it hotter
              Mark
              • Bob C
                • Apr 2005
                • 95
                good advice all around,
                I find, with sufficient dome insulation, when the dome turns "white" after a blazing fire, i wait and let the heat radiate down to the floor some more as well as spread the embers across the entire cooking surface. Take it's temp and start cooking
                Great pizza, a cold beer,a great cigar and great friends...my idea of a great time
