Oven Curing
This is a sticky topic.
Re: Oven Curing
You sure want to cure before, if you cover the dome you will trap the moisture in,my opinion is to use it AFTER curing 10 times for pizza and after cover it.Comment
Re: Oven Curing
Quick question just finished my keystone today! And it's 40 degrees and will be 30 tonight. I have a space heater in the dome covered with a tarp/blanket/tarp. I sponged the joints before closing but I want to keep it moist while keeping it above freezing. The space heater is at its lowest setting which is probably 55' f in the dome. Think I should keep a bucket of water in the dome to keep the moisture up?Comment
Re: Oven Curing
I don't think it's necessary to put the water in there. Mine was curing at around 80 F with no water in the summer so 55 f no prob. I had pretty tight joints in my dome.Comment
Re: Oven Curing
GuddayQuick question just finished my keystone today! And it's 40 degrees and will be 30 tonight. I have a space heater in the dome covered with a tarp/blanket/tarp. I sponged the joints before closing but I want to keep it moist while keeping it above freezing. The space heater is at its lowest setting which is probably 55' f in the dome. Think I should keep a bucket of water in the dome to keep the moisture up?
if its commercial high temp mortar sorry can't comment, other than telling you to check to check with the manufacturer.
If you curing some homebrew mortar (as opposed to heat tempering the dome), I recon you being safe and prudent. the space heater will stop it from freezing and watering a cement product during curing is always a good idea.
I live in a hot climate where any cement work is usually damped daily and covered from the hot sun. protecting it from freezing is novel concept to me
go well
regards dave
PS http://www.fornobravo.com/forum/f16/....html#post3871
I think this explains things best...thanks TszarLast edited by cobblerdave; 12-25-2013, 03:59 PM.Measure twice
http://www.fornobravo.com/forum/f28/...ock-17190.htmlComment
Re: Oven Curing
Thanks, it's a home brew and all the joints are tight except the keystones, could never get them perfect!Comment
Re: Oven Curing
I wanted to ask James another question about the oven curing process. My oven is in its fifth year of operation. Recently there has been some real time gaps between cooks, mostly due to inclement weather. Anyway, is there a length of time between cooks that I should consider redoing the curing process due to accumulated moisture in the oven?? Rather than just firing it up hot to 7-800 degrees again? I haven't been doing it but thought it might be better to do so.
Thanks,
Jim BobComment
Re: Oven Curing
Anyone on this thread point me to a simple way of making the door for the dome? ThanksComment
Kindled with zeal and fired with passion.Comment
Re: Oven Curing
Thanks. Also is there any merit to cutting away the excess vercrete that goes out past my dome?Comment
Re: Oven Curing
Will do that. Thanks. Not the seal part , suppose it's not nec after I cut the excessComment
