The scary fire issue
  • enzo
    • Nov 2009
    • 20
    I think I've discovered the answer! I'm sure this is probably obvious to most people on this forum, but, there are scary fires and then there are SCARY FIRES.
    I had been having problems getting my oven to carbon burning temps i.e. the walls turning white. I have since purchased proper seasoned (about a year) red gum, burned it and Presto... white walls within an hour.
    There seemed to be quite a difference in the intensity of the heat/fire as it required much less wood to get to temp.
    Does this sound right? This would be useful info for newbies like me.
  • texassourdough
    • Nov 2006
    • 1719
    Re: The scary fire issue
    Hi Enzo!
    Crappy wood can certainly slow the heating and make a lot of crap in the process.
    I am in the Texas Hill Country where we have a "trash tree" that is a juniper that is absolutely free and burns like crazy - even when green! (A month or two of aging makes it incindiary!) When one tries to cook over it in a bbq it gives a tarry, resinous taste but in the oven it is a delight. Burns like hell and clears in aout 45 minutes. AND, at the high oven temps it is ODORLESS. And.. FREE! I love it! While it is fine for pizza i usually switch to hardwood just so it burns longer.
    It is my understanding that in the Middle East juniper is a preferred bread oven fuel for it heats fast. Do you have anything like that down under?
    Bake On!
    jay
    • enzo
      • Nov 2009
      • 20
      G'day Jay,
      I'm fairly new to the game, so I haven't sussed out too many wood type options yet. Sure seems as though there's an awful lot to learn about WFO's. I have only ever burned red gum, both for my open fire and WFO, I look forward to the on-coming disasters and triumphs.
      I know experimentation is the key, so as we say down here, "let's suck it and see"
      Cheers!
      • heliman
        • Sep 2009
        • 1181
        I only use Whitegum (Wandoo) and Mallee roots. I pay $15 per small bag so it it is very expensive, but well worth the spend as the wood lights with 2 small firelighters and burns like crazy. I have been getting temps around 480 C with this setup and produces a good pizza fire.
        I did experiment with the cheaper Jarrah but results were poor so now only use the Whitegum/Mallee combo. Not sure if those trees are available down your way though but I would guess so!
        Rossco
        / Rossco
        • enzo
          • Nov 2009
          • 20
          Yep! Mallee is great wood, just very expensive down in Melbourne. I've heard it burns HOT and for a long time.
            The best wood is free wood. I try to reserve a few heavy, split, dry pieces after about 45 mins then finish with some thinner bits so they're all burnt up when I'm ready to remove some coals and cook.
            • Neil2
              • Oct 2006
              • 1374
              "The best wood is free wood. "
              These ovens are not fussy. I've used many different woods and they all will do the job. The only essential criteria is that the wood is well seasoned.
              • heliman
                • Sep 2009
                • 1181
                A quick sample pic of the woods that I use:
                White Gum (Wandoo) left
                Mallee root right
                Rossco
                / Rossco
                • rhollman
                  • Sep 2009
                  • 9
                  Is that actually the root of a tree ?
                  • heliman
                    • Sep 2009
                    • 1181
                    Yes indeed ... allowed to dry and split (using a hydraulic splitter as they are VERY tough). Another excellent option is "vine stumps" - they burn forever too and at a high temperature. Unfortunately these are hard to find.
                    Rossco
                    / Rossco
