Originally posted by 1 strover
View Post
Re: Large WFO in India
Originally posted by 1 strover View Postjust one wider door opening with the chimney right over it?
Can you draw your flue concept on paper, that way it will be easier to give help.
had a quick question, i had planned for 2 small doors opening to a height of14 inches so that i could use more of the space but do you'll think that it would be better to have just one wider door opening with the chimney right over it?
david s,the castable under the herringbone pattern is a refractory concrete used to insulate larger furnaces again i hope that should be ok,
brickie in oz, thanks a ton
yes i would be insulating the top with a coat of thermoset followed by 2inches of insulating blanket followed by a 6inch fiberglass blanket, hope thats enough.1 Photo
It looks like there is no insulation under the floor bricks. You may regret that decision, unfortunately it's probably a bit late now to retro fit it.
A wood fired oven is supposed to be carbon neutral in that you can plant more trees to make up for the fuel burnt, something you cant do to offset fossil fuel use.
1 Strover, sorry, I jumped to some conclusions before I knew the full story. It sounds like you have the bases covered better than I thought. I also wasn't aware how far into the project you are- at this point, there's obviously no backing out. I'm still a bit concerned that you have no one with oven building experience involved in this project, but, hey, it looks like it's almost done, so let's see how it performs.
Are you making two different pizza doughs? I didn't mention it earlier, but that could be another issue- your deck oven dough may not work all that well at the (most probably) higher heat of the WFO.
How are you insulating the hearth?
Regarding the environmental impact of gas/electric deck oven vs. wood, yes, the deck oven is burning fossil fuel, but, from a pollution standpoint, the WFO is belching out many many times more smoke.
Very nice build, it should work great as a commercial oven.
Are you insulating over the top?
:-Edit
What sort of mortar are they using, is it a bought product or made on site by them, if made by them what is it?Last edited by brickie in oz; 01-21-2012, 01:31 PM.
Originally posted by scott123 View Post1Strover, let me get this right, you've never built a WFO, you've hired other people who've also never built a WFO and you're planning on building an 84 x 96 barrel vaulted oven with an 18" dome height?
Originally posted by scott123 View PostIt's one thing for a first time oven builder to build an oven in their back yard, make a few mistakes and learn through these mistakes, but in a commercial setting, in an oven of that size, to not have someone with large oven building experience involved is crazy and possibly even dangerous.
Originally posted by scott123 View PostAn oven like this takes major engineering know how to deal with the massive lateral forces involved. This is not like building a furnace.
Originally posted by scott123 View PostAnd that's building the oven. The pizza making side also has issues to consider. Have you ever worked a WFO? It's nothing like a deck. You need major thermodynamic know how to run a WFO in a commercial setting- and that's a well built WFO. Getting consistent high volume pizzas out of a WFO takes months, possibly even years to master.
Originally posted by scott123 View PostIf you're doing 1000 pizzas on good days, then why complicate your business model with a WFO? If you really want to avoid headaches, just get another deck.
here again a few pictures of
the arch support form ,the side wall completed an ready for filling with quick set castable.
then the castable poured and finally starting to build the arch for the dome of the oven,
in hindsight i wish i built a bigger form so that i didnt have to slide forward, if it were the size of the oven i could have just built the whole dome and kept the wooden cast in there and burnt it later.5 Photos
here are a few more pics this is day 2 the castable is in place and we start laying the hearth in a herringbone pattern,
after that we built the side walls which will ride to a height of 9 inches from the cooking surface,
you can also see the arch support form i made so i can build the arch in it and once the keystones are placed ill drop it down and slide it forward.5 Photos
here are a few more pictures from the first day of the build.
in these pictures you see us pouring the castable and leveling it3 Photos
here are the first five pictures from day one
we did a whole lot on the first day ,
we made the base for the oven . laid some natural hard rock tiles on the base , then we laid bars and tied them up for the castable on top of the stone platform and we also poured the castable5 Photos
