Creating draw in flues
  • Creating draw in flues
    Hi folks. New here and in process.
    Due to limited space I am considering building an arch oven left to right. Looking a bit like a tunnel chamber but stretched out and the acces on the side in the middle. It will have a rear vertical wall and a vertical face with access through an arch. On the outside of said arch will be the access arch that doubles up as the flue vent.
    my concern is about exit flow as the front wall is vertical and I haven't seen this anywhere. All the ovens seem to have a down slope to the exit door and out to the chimney flue. A bit like the attached but with an access door arch and external chimney.
    is this doable??
    Sorry if photo i fringes anything im not phone literate enough to edit it. However it is from breastfeeding ovens whom I have nothing to do with, only photo similar to my idea.
    Thanks all.
