I always loved your glass door. Sorry it cracked but glad it can be updated with a new piece of glass.
Glass door for the view
Would it work to order two equal-size pieces of glass plus gasket rope as a spacer, and then simply put extra-high-temp silicone around the edges to seal it off? How much of a gap would be optimal? And would it be preferable to pump some kind of gas into the gap to displace the regular air?
Trying to think through whether this might not be a preferable alternative to an insulated door (stainless steal wrapped around a CalSil block, backed by wood).
Long time, I still send new builders your IT design.Last edited by UtahBeehiver; 09-16-2024, 08:28 AM.
Very nice. Would you consider double glazing like conventional kitchen ovens, to get the insulation benefit?
Well, after 16 years of use, the glass in my "door with a view" has cracked. However, not because of thermal expansion issues, the glass exceeded all expectations in that regard (cleaning soot off of 850-degree glass with cold-water-drenched towel). The problem came down to careless handling. Regardless, it brought me back to this post to see if I had mentioned where I ordered the glass from. And I did (onedayglass) Not surprising, price went up ($115 to $150) but not bad over the course of 16 years (CAGR of only 1.84 pct per yr) and still well worth it for the utility I have gotten from this door over, now, the better part of two decades.
Note that the drenched towel stress test referenced above was to clear the glass in the middle of a bake, a practice I abandoned after I discovered the tip provided to exceloven below.
Jim
Last edited by UtahBeehiver; 09-15-2024, 05:31 PM. Reason: removed commercial hypelink but left name
Re: Glass door for the view
A glass door would be nice so you can see into the oven, but unless it is double glazed, will not insulate particularly well for long roasting and baking. This is why all commercial ovens have double glazed doors.
Beautiful Door Saved it so Hubby can see it, maybe a early birthday/christmas present.
Hi Amac and Laku,
Still investigating different options, but thanks for your interest. I have no internal light fitted and the beauty of hebel is that I can check the opening first for size before cutting/ sourcing the glass. Had a fire up last night; list included several pizzas, two dessert pizzas, one beer can chicken, one loaf of bread and plenty of heat in the oven this morning to warm up a quiche for lunch today. Life is tough aint it!
I had thought that from some post or other, and that a water jet cutter was needed, but it seems that is not true according to this:Originally posted by Laku View PostI think someone mentioned earlier that ceramic glass can't be cut like ordinary glass. But that's just my recollection so take it with a grain of salt.
Neoceram - Heat-resistant glass ceramic for high efficiency heating appliances
one of the features of neoceram which jim used:
Can be cut with regular glass cutters for immediate customer service
Hi Geoff
Can't help you with any answers but I had a similar idea - instead of shaping the glass to fit the entire door as jim has - to put a rectangular window in some kind of wooden frame. I think this ceramic glass can be cut like normal glass, so maybe by raiding the local recycling centre an old electric oven door could supply the glass and I could do it myself.
I would do the double glaze - but I am not sure what the implications are. You have to keep the panes not more than x mm apart to allow for maximum insulation, and also how do you seal them, or would you get a local glazier to do that part.
Do you think that would allow enough light to see or do you have some internal light fitted?
Hi fellow chef extraordinares (?)
I have cut a new hebel door for my oven and was planning on putting a smallish window say 150 x 100 mm to check on the progress of roasts, breads etc without removing the door and thus letting heat out. My question is, should I double glaze by putting one piece inside and another outside or run with a single piece? Hello from beautiful (chilly) Tasmania.
Geoff
look forward to see those plans. I have a bit to do before I get to needing a door - still have to finish the oven - but I am on the lookout for good ideas and your IT (which I modelled mine on) and doors are up there with the best.Originally posted by jcg31 View PostI keep meaning to post the plans for the insulated door (my second favorite project) - - perhaps this weekend. If you find you can only get the thermal tape in lengths far exceeding your needs, I still have some left and would be happy to send to you if you will pay the freight across the pond.
Jim
Hopefully I won't need to take you up on that offer but I do appreciate it and might be back to you. thanks again
Aidan
Jim
Originally posted by Amac View Postthanks Jim
I did follow up and even got a quote from onedayglass ($108 without shipping costs).
It is available in the Uk and what appears to be a very similar product to neoceram called Robax I can get from local glaziers:
It seems very similar as I say but I got a quote of 120Eur ($158) to cut my semicircle.
Not sure I have the engineering skill to make that door anyway so I will leave it till later and meanwhile I will maybe try to copy your wooden door ( I found on some other thread) instead
. I am looking for that glass fibre tape. One or other of these should do the trick I guess
High Temperature Tape: Heat & Flame Resistant & Thermal Insulation Tape for Wire Cable Hose Protection
