Re: Too dirty?
you could weigh them and then measure the dimensions to calculate the density.
After you know that, here is a good reference that could help:
Firebricks are actually fire clay bricks. Thermal conductivity. Cutting with diamond wheel.
Re: Too dirty?
Here (finally) is a picture- dug 400 or so of them out of the garden paths. Can anyone tell by looking what type of firebrick these are?1 Photo
Re: Too dirty?
Thanks! Great idea. Don't have an oven yet, but I do have a couple of campfire rings, and can make a makeshift fire pit or kiln-like structure...Originally posted by Tscarborough View PostYou don't need an oven, just build them into a very loose pile and build a fire on top of them.
Re: Too dirty?
Re: Too dirty?
if you already have a pizza oven, cook them!
The high heat will clean them nicely. Make sure they are dry.
Re: Too dirty?
Definitely firebricks, yellow with clean, sharp edges. Tough too, a 1000lb limb from a locust fell and drove several 2-3 feet into the ground, I haven't found any broken pieces yet..
I am trying to attach a picture now... Here goes.1 Photo
Re: Too dirty?
Easiest way to clean any "dirty" bricks is with a pressure washer with a wide adjustable p]spray rather than a pencil jett them drain and then mortar them into place.
Neill
Re: Too dirty?
they are probably red clay bricks, not fire bricks.
Re: Too dirty?
Wash and scrub and then dry them. Are they really firebricks?
Chirs
Too dirty?
The previous owners of the house I am about to buy have used hundreds of fire bricks as pavers for paths. They have been in the ground for 7-10 years. Can they be cleaned up and used in an oven? Any recommendations on how to clean them?
