Originally posted by gugahulk
View Post
Starting my barrel vault
Re: Starting my barrel vault
Forgot to tell you David my end walls front wall and back wall will 100% be inside of the vault roof. Do you think I still need buttressing on top of this?
Another alternative is to use insulating fire brick to buttress the walls.
Not really, I braced mine with insulating board then welded steel bracing around it.Originally posted by gugahulk View PostBut the only way to do that is increasing my mass on the side walls right? Which is something i am trying to avoid
Take a look:
Hope that helps.
But the only way to do that is increasing my mass on the side walls right? Which is something i am trying to avoidOriginally posted by david s View PostBetter to build the vault over the end walls and buttress, but skip the bracing IMO
No, the bracing is outside the bricks. With an oven the problem is that steel bracing would be covered with insulation making any adjustment at the nuts difficult.Originally posted by gugahulk View PostActually the iron is a good idea. But will that withstand the heat from the firebricks? Won't the iron get too hot?
Actually the iron is a good idea. But will that withstand the heat from the firebricks? Won't the iron get too hot?Originally posted by david s View PostThis may help you.
Many folk decide to build a barrel vault rather than a dome in the belief that the construction will be simpler. Because of the barrel vaults inherent instability and problems to correct this, it turns out to be more complex. The only advantage a barrel vault has over a dome is its interior form which makes it more suitable for cooking large batches of bread.
This may help you.
Many folk decide to build a barrel vault rather than a dome in the belief that the construction will be simpler. Because of the barrel vaults inherent instability and problems to correct this, it turns out to be more complex. The only advantage a barrel vault has over a dome is its interior form which makes it more suitable for cooking large batches of bread.Other disadvantages are poorer circulation leading to cool spots, though this is more of a problem in a kiln than an oven.1 PhotoLast edited by david s; 06-18-2015, 02:29 PM.
Thanks david, here is my idea. I am not sure what to do with the buttressing situation, I am just affraid it might not hold and its holding my build. The first 4 courses are straight up on the sides of the vault that a low arch. See picture below. Any ideas you can give me?Originally posted by david s View PostGigahulk, here's a point you may want to consider. "The end walls of a barrel vault should be under the vault, not outside it." This is the general rule for kiln building, where temperatures are much higher and expansion is greater. The expanding vault has a tendency to push the end walls out and steel bracing is required to hold them in for kilns built this way. It is a bit more tricky to build the end walls first and then the vault over the top, but the result is better. The same applies for ovens although the problem is less because the temps are lower and thermal expansion is smaller.
Hi, I am building a barrel vault similar to yours. I notice you did not use any buttressing on your build. I am having a very hard time as i dont know how I would use it. Does your vault has any buttressing?
here are a couple of the inside after my first full burn.3 Photos
Here are a couple more pics of my progress . Roofing and fascia board is supposed to arrive on wednesday.3 Photos
The use of wood will tend to go down a little over time, I use less wood now to get my dome to clear than I originally did.Originally posted by jim81147 View PostWell I burned the carbon off today . I was surprised at just how much wood that takes to accomplish
The oven looks really nice now , not all nasty and sooty. Time to do some burns now so I can figure out timing , then on to making poolishes !!!
And the soot will return at the start of each firing.
Chip
