Originally posted by gugahulk
View Post
Starting my barrel vault
Re: Starting my barrel vault
Another alternative is to use insulating fire brick to buttress the walls.
Originally posted by gugahulk View PostBut the only way to do that is increasing my mass on the side walls right? Which is something i am trying to avoid
Take a look:
http://www.fornobravo.com/forum/43/t...s-19037-2.html
Hope that helps.
Originally posted by david s View PostBetter to build the vault over the end walls and buttress, but skip the bracing IMO
Originally posted by gugahulk View PostActually the iron is a good idea. But will that withstand the heat from the firebricks? Won't the iron get too hot?
Originally posted by david s View PostThis may help you.
Many folk decide to build a barrel vault rather than a dome in the belief that the construction will be simpler. Because of the barrel vaults inherent instability and problems to correct this, it turns out to be more complex. The only advantage a barrel vault has over a dome is its interior form which makes it more suitable for cooking large batches of bread.
This may help you.
Many folk decide to build a barrel vault rather than a dome in the belief that the construction will be simpler. Because of the barrel vaults inherent instability and problems to correct this, it turns out to be more complex. The only advantage a barrel vault has over a dome is its interior form which makes it more suitable for cooking large batches of bread.Other disadvantages are poorer circulation leading to cool spots, though this is more of a problem in a kiln than an oven.Last edited by david s; 06-18-2015, 02:29 PM.
Originally posted by david s View PostGigahulk, here's a point you may want to consider. "The end walls of a barrel vault should be under the vault, not outside it." This is the general rule for kiln building, where temperatures are much higher and expansion is greater. The expanding vault has a tendency to push the end walls out and steel bracing is required to hold them in for kilns built this way. It is a bit more tricky to build the end walls first and then the vault over the top, but the result is better. The same applies for ovens although the problem is less because the temps are lower and thermal expansion is smaller.
Hi, I am building a barrel vault similar to yours. I notice you did not use any buttressing on your build. I am having a very hard time as i dont know how I would use it. Does your vault has any buttressing?
Originally posted by jim81147 View PostWell I burned the carbon off today . I was surprised at just how much wood that takes to accomplish The oven looks really nice now , not all nasty and sooty. Time to do some burns now so I can figure out timing , then on to making poolishes !!!
And the soot will return at the start of each firing.
Chip
