I am (I think) within dome-closing distance -- one more chain then a plug ought to do it.
I started having problems with bricks sliding inwards about 3 chains ago. The solution for me, which I hadn't seen elsewhere was to use a 'lock stone'. Think of it as the opposite of a key stone:
- A key stone locks the whole chain by being the last brick in place -- once it's in place, the whole chain can't slip inwards because they push against each other.
- A lock stone means after completing one chain, I immediately place the first brick (or 2) of the next chain. The IT supports this brick while it sets, so that the next day I can set the rest of the bricks in the chain and have something immovable to lock against until I complete the whole chain and place the key stone.
This has worked well for me so far -- no slippage, no need for extra support mechanisms.
I need to get a bit more fireclay and sand for mortar mix before I continue, but going well. I'm getting better at this as I go along of course -- now that I'm getting close to completion
. At least I'll be reasonably good with the mortaring for my exposed exterior arch.Looking into getting blanket and chimney soon. Blanket is pretty straight forward, but not sure on exactly what kind of duravent to get yet. Consensus seemes to be 8" duravent is best, but would 6" be just as good if my chimney is particularly tall? I.e. does taller == draws better? My Chimney is likely to be about 7' tall to make sure i'm 2' higher than any nearby rooflines.
