Re: Newbie question: Foundation on slope
I'm new to ovens myself but have done some landscaping. I think the first question to answer is just how much of a slope are you trying to deal with. A retaining wall for 2' will be a much different animal than one for 4'? You'll need to deal with the retaining wall at the bottom of the sloped area but may have another wall to worry about on the other side of the patio after it has been dug out. There are a number of ways to go and a lot of options but giving a more exact height would be helpful.
Good luck on the project!
I built my oven on a sloped site. I had a retaining wall poured that was 3 feet tall, and built my hearth on top of that. Cost of the retaining wall was pretty significant, but I needed it to make my back yard usable. Plus I had a design in mind for a whole kitchen area. click on the link to my build and you can see the site in the sketchup in the first post.
If you don't want a wall, I would dig out the slope for the shape of your foundation and build up the wall around it with CMU like you can get at any big box retailer or masonry specialist. Use rebar to tie the CMU to the foundation and fill every core with cement (instead of every other) to give it more strength.
That last line is ...with a batter. Typing in a phone sucks....there's a reason I work with stone and not a cpu
And that's blockwork, not Blackwell...sheesh
The slope you are referring to is called batter. Retaining wall systems are built this way to combat pressure from the ground behind it. I can't really recommend a specific brand, because I build with natural stone or natural stone veneer over poured concrete or Blackwell. Like a dry laid stone wall, modular wall systems don't need a concrete footing...they are flexible to movement. Upward thrust is less concern than lateral pressure, so it's important that you have drainage, cut the bank down in steps, and buildOriginally posted by super80 View PostHi stonecutter, my masonry experience is limited to say the least
, but I am a fast learner. Can you recommend a brand/source for modular retaining wall units? Most of the retaining wall tutorials I have found show the use of decorative blocks, which when stacked are not 90 degrees, they more or less have an angle to them as the retaining wall rises in height. I assume from my research this is referred to as a segmental gravity wall. Should I build a cantilever wall? Also, does the retaining wall have to reside on a poured footing?
Thanks again!
wall with a baa batter
Hi stonecutter, my masonry experience is limited to say the leastOriginally posted by stonecutter View PostIf your masonry experience is little to none, then consider building the retaining wall with modular wall units.
Thanks again!
Many thanks for the replies!
If your masonry experience is little to none, then consider building the retaining wall with modular wall units. Use free draining backfill and make sure that you install drainage behind it. RR ties are junk...even though they are treated, they rot quickly when they are constantly in contact with moisture. Even if they did last 20 years...they stink and look like crap....IMO.
Any slab or wall built on a sloped grade is no different than one that isn't...that is to say, you want your support (walls/foundations/slabs) built at right angles. Do not follow the slope of the grade with your masonry.
I had the same issue with my build, although I think my slope was more like a foot, front to back. Gulf had some good advice on my build thread, with pictures, here: http://www.fornobravo.com/forum/f8/3...-dc-18213.html
I should note that I still haven't gotten around to putting a retaining wall in around my excavation, and haven't had a problem yet, 8 rainy months later.
Hello!
My name is Victor and I am in the early planning stages of adding a WFO to my back yard in Georgia. Probably going to go with a modular kit.
The first thing I need to determine is how to go about creating the foundation on ground that slopes down? Are there any resources someone can direct me to that address this? I estimate the ground slopes down about two to three feet from the front to the back of the slab I want to pour, so I would need to build up the sloped area. Should I make a retaining wall out of railroad ties? New to this so any advice would be appreciated
Thanks!
