Heat resistant mortar - hydraulic or ceramic drying??
  • Frances
    Re: Heat resistant mortar - hydraulic or ceramic drying??
    The stuff I bought is not premixed, and I can add 20% of cement to it for areas which need to hold especially well (like the top of the dome, I guess - but any other recommendations are welcome).
    Yep, heat-set and air-set, that sounds about right :-) (and I thought I was good at translations...) Good to know I can use either one, too.
    Workability, no idea, but I'll find out when I get that far. The price is good (about 10 USD for 25 kg). And once its mixed, without cement obviously, you can continue working with it for hours. He said I need pressure joints of a couple of mm max, but only on the inner surfaces. Cos there's no way I'll get small joints on the outside!
    Thanks for the help,
    Frances
  • Hendo
    Frances,
    I wonder if we're getting tied up with nomenclature, across cultures? Perhaps the 'hydraulic' drying is an air-set mortar and the 'ceramic' a heat-set mortar. I'm just guessing here, but it may explain it.
    My brickie said most industry kilns etc use a heat-set mortar, the bricks laid on a form (like a gigantic Alan Scott barrel oven), and when the forms are removed, the bricks are quite stable as they are self-supporting. When the kiln is ramped up, the mortar sets/cures/hardens thoroughly.
    For ease of assembly, my supplier recommended I use an air-set mortar, as it sets up more quickly and you can get on with the next brick sooner.
    Here, air-set mortars are generally available both wet or dry, and are available in a range of alumina contents, and heat-set mortars mostly dry, with higher alumina contents (hence their use in kilns etc).
    Hope this helps.
    Paul.
    Last edited by Hendo; 09-18-2007, 11:37 PM. Reason: sets/cures/hardens - ie achieves max strength
  • nissanneill
    One has to ask.
    Does it really make much, if any difference, provided that they both do the job as required?
    The only factors which might sway the consumer is:
    ? price
    ? workability
    ? freshness (or useby date whether premixed or powdered)
    ? accessibility/availabilty
    ? characteristics (maximum recommended thickness, etc).
    Neill
  • DrakeRemoray
    Is one type premixed in a tub and the other a dry powder to be mixed with water?
  • Heat resistant mortar - hydraulic or ceramic drying??
    I have been looking in the forum, but didn't find any mention of this:
    When I went to get my firbricks, the guy asked me if I wanted hydraulic drying mortar (I gather this is cement based and hardens as it cures) or ceramic drying mortar (which reaches its final strength through heat and only after the oven is fired). The Pompei plans obviously use cement based, but will the other stuff work too?
    The thing is, this guy gave me an I-was-building-ovens-when-you-were-still-wearing-diapers look and I ended up with the ceramic sort. He said it was better, because it expands and contracts with the rest of the oven when heating up, so you don't get cracking others have mentioned. He also assured me that it was easy to build with. So what is the down side? Has this been discussed on the forum before? What have I bought???
    Frances
