Re: High Heat Mortar Primer
Cecilia,
I think I paid about $20 for a 90lb bag. If you are in KS, you can buy direct, right?
Lars.
This is a sticky topic.
If you are mixing the fireclay with sand anyway, then the coarser fire clay should be perfectly adequate.
the reason why I ask about pricing is because it's listed for $.24 - at the most. I'm pretty sure a 50# bag isn't 24cents! ha!
Anyway, if I don't get a reply from them, I will have to break down and call. ugh.
cecelia
My guess is that, like abrasives, the higher the number the finer the grain. A google search of "clay mesh" returned kaolin at 200 and 325 mesh, but kaolin is a super-fine porcelain clay.Do you know what the difference is between the meshes? 35 or 50?
Usually fireclay comes in a fifty pound bag.And how do they price it? Per ounce or per pound?
Ah thanks! That makes sense to me.
I'm still waiting to find out about getting a 50# bag -
What about lime - is that something that Lowes or Home Depot would carry? Because it seems like they don't carry much of anything except the basics! I don't even think they carry very fine sand!
c
CeceliaOriginally posted by cecilB View Postbut some is called 35 mesh, and some is 50 mesh - can anyone explain? Can I use this for the homebrew mix?
Cecelia
It most likely refers to the mesh size used to sift it. 35 openings per inch or 50 openings per inch. I would suggest the finer clay but, I don't see any reason why you couldn't use either in the homebrew mortar mix.
Best
Dutch
- Likes 1
I just recently completed the dome and curing and used the home brew recipe.
I used 3:1:1:1, sand, fireclay, portland, lime. Seems to acting in a normal manner so far: thin cracks in places, hollow sounding, but snug and secure. For myself using this mix made sense, but the true refractory mortar must harden much harder.
Be sure to mix all the 3:1:1:1, or 1/2, first, before adding water. It's very sticky and should hold bricks almost to vertical (I had to use a form for the last three courses). Also make sure to soak bricks and hydrate and cover
Cecelia,
I have posted my 'recipe' and thoughts on it many times, but I used 3:2:1: (1/2) very fine sand, fireclay, portland, and lime. It is a GREAT mortar.
My bricks are all in place, yes,but I guess after you fire a few times, and ALL the moisture is out if them, they really do take on a hollow sound when tapped. I have made pizza 5 or 6 times. ( we made 5 pizzas saturday night). and it's holding together fine.... it's just, my transition from dome to chimney could have been a little more elegant.
Don't be scared off of 'homebrew' mortar from my comments. Heat is very powerful and it is difficult to contain it without some cracking and loosening of the many many pieces making up the dome.
Good luck.
L.
ps. when I do a test of this mortar mix ( mix up , cure, and fire several times) I will let everyone know how it turned out.
Thanks, Lars.
I did email them, but maybe I should call them.
Did you mix your fireclay with the portland cement and sand and lime?
If the bricks are cut properly, though, they won't just be hanging, right?
I may just have Capital Concrete order the heatstop50 for me....
Cecelia
I used fireclay from Lawrence.
It worked fine as far as I know, but I DO notice the bricks, when you tap on them ( and I don't do this too hard) seem like they may just be hanging in there...
I have a question about fireclay - there is a place called Brackers in Lawrence, Kansas, - a pottery supply place and they carry fireclay - but some is called 35 mesh, and some is 50 mesh - can anyone explain? Can I use this for the homebrew mix?
Cecelia
I'm sure if there was an issue there would be far more upset people on forums like this. You will get the odd crack or 2 but even if alot of the mortar failed what karl said is right it is really the brick pushing on the bricks either side of it wedging it in placeOriginally posted by Mierkmike View PostI made up my refractory morter using the 1113 mix. I was later told by another oven builder that the Portland cement will disenagrate at 600 degrees and the bricks will get loose and fall in. Has anybody experienced this?
I do not think I have mentioned this on the forum during my build. I was struggling figuring out how to do the transition dome/opening as well. Most of the advice on the forum was to do the opening arch first and then do the dome rings. I ended up doing it simultanously and with no precutting of bricks. In fact I allowed the bricks to protrude both in the radial and circumferential direction (when necessary) around the transition. As soon as I reache the height when I could do a continous ring (over the opening) I went in and cut off all the protruding bricks and also cut a suitable angeled surface for the next continous ring bricks in the top bricks of the opening arch. It was not very hard to do this cutting and I would recommend the method (clearly above the "mortar fill-in" method and as a time saver for those who consider the "taylor pre-cut" approach).
Karl
MierkMike,
This was the assumption I have made from what I have read. The mortar will, at best, retain it's shape and adhere to the bricks. At worst, it will crumble.
If you never fired the oven, it would stay together a very long time. I was told that the fire clay, when it gets up to 800-1000 deg. F. will become solid and reject moisture. If this is the case, everything should work fine. I plan to test this by curing some mortar and firing it. I am curious myself.
That was the exact reason I made every brick in my dome tapered by 11 degrees in 'horizontal' ( which becomes vertical at the dome top) and when I got up to 8 chains, I arched over the top [left-right and front-back] That way, if the mortar were to completely fail, my bricks would still be very stuck in place!!!
Lars.
Karl, thanks for that info. I am right at that point of arch opening to dome. The cuts there are pretty time consuming and baffling. I am trying to keep the brick pieces as large as possible, but there are some smaller ones placed in a thicker than normal mortar gap. Be glad when this part has passed.
From many previous posts I have understood that the large gap(the wedge) on the OUTSIDE of the brick is OK because it doesn't receive a straight dose of heat. I have been trying my best to snug the brick edges together so the gaps on the inside are very small.
Would it be acceptable to say that home brew mortar should be at least 1/8th" thick, but not more than 1/2" thick?
