Re: Round shape
Thanks Tscarborough,
The outer cylinder sits mostly on the normal block stand; it didn?t seem like the extra support was doing that much when I drew it out. I was thinking of putting some extra support in the middle beforehand. Does this layout make more sense?
Mike
Re: Round shape
That does not look like it is needed. Far better to run the 4" across the middle, making it an "H" shape.
Re: Round shape
-Ok
So if I am following the plans on the size of the stand, this is what it might look like with extra support. as in an extra row of 4x8 block on the inside of the stand. If I do this, should I extend this extra support over the front opening of the wood storage area?
Does this make sense?
Mike1 Photo
Re: Round shape
I tihnk Extra support depends on the shape and size of the stand and hearth slab, if you do it like Balty's then the decorative enclosure goes all the way to the lower slab, but he must have something else supporting the hearth slab? So in his design I would say "Yes there is extra support"Originally posted by Mike D View PostSo, extra support? One layer of brick? Should I use cored brick?
On layer of bricks and any bricks should be fine a cylinder will make a very strong self supporting structure.1 Photo
Re: Round shape
You guys are great and fast,
Azpizzanut- thanks for the thought, but I have read the plans many, many times. I have also read tons of posts from start to finish.
The plans just call for the vermiculite layer to be pored after the slab with the same outer framing. But I think every one is on the same page about not putting it under the decorative enclosure. I like the idea of making an island or I guess using the FB insulating board.
I guess I could slightly slope the top toward the back, I was also thinking of putting a small round shape on the top with the stucco so the top would not be completely flat (to not let water pool up).
I tried to make a sketch of the oven with my lame program.
But take a look at Balty Knowles oven here (reply #10)
I live in Berkeley California, I was in Phoenix on vacation (Pizza Bianca is Famous), but still no snow or real cold.
Thanks Mike1 PhotoLast edited by Mike D; 11-01-2010, 10:52 PM.
Re: Round shape
I like muscat's idea of the concealed internal roof, especially since it's not likely to fill with snow in Arizona. Around here that plan would entail serious flashing, but in Arizona, a layer of roofing membrane would seal the oven. Do I envision an elaborate lipped spout with a copper downspout? Hmm.
Re: Round shape
I think I am getting the idea of what you are planning now.
Correct me if I am wrong, but you want to build a Pompeii oven and then build a cylindrical shaped enclosure around it. The cylinder being larger than the dome circle to allow the front of the cylinder to include the arch? So the circle of the dome and the circle of the cylinder will not have the same center? I have modified one of my sketches to illustrate, see attached.
If this is what you are going for, I would consider a slopping roof within the cylinder, you would not be able to see the roof from the outside and you can make it out of whatever roofing material you want, you would just need seal around the edge and to allow somwhere (at the back) for the water to get out.
Adding the cylinder would add weight, but no more than a square enclosure would, but you wouldn't want this weight on the insulating concrete.
One option that comes to mind would be to lay the hearth slab in normal full strength concrete lay a ring of bricks for the cylinder enclosure and then fill inside this ring with insualting concete, build the dome, build the cylinder, fill with insulation, build the roof and you are done.1 Photo
Re: Round shape
I'm thinking a sketch is in order here. I can't envision why the decorative brick wall would be on top of the vermiculite layer. That means the vermiculite would be exposed to the outside, which is never a good idea.I was worried about the extra weight of the decorative brick (cylinder) denting the vermiculite concrete, is this and issue? Would it be better to just put it on the slab.
So let's see. Your block base is already built, the support slab poured, and the vermiculite is spread from edge to edge. Am I right so far?
Is your decorative brick not going to cover the base? That's what my assumption was. I was envisioning a single cylinder rising from the base, with the support slab cast inside the brick ring, hence my call for a support layer inside the brick ring.
As far as the cover, neither brick nor stucco is particularly waterproof. At the very least you will need a significant slant to prevent standing water on your top.
Re: Round shape
"- If I use vermiculite/concrete insulation on top of the slab, will it support the weight of the bricks? "
A picture or diagram would be useful, but if I understand correctly, you should cut back the vermicrete layer so that your outer brick shell rests directly on the edge of the structural slab.
You don't need the vermicrete layer over the entire slab - just under the hearth, inner brick dome and dome insulation.
Re: Round shape
Hi Mike D,
You might get answers to some of your questions by downloading the free Forno Bravo Pompeii oven plans. They describe an oven building process from start to finish. There are tables that show how to size the base and hearth.
I recently made hearth insulation from perlite and portland cement. It hardened and became strong enough to support the hearth bricks and dome bricks.
Cheers,
Re: Round shape
The decorative brick is in a cylinder shape (round form around the dome), as opposed to a square like most ovens. Sorry about the confusion.
Mike
Re: Round shape
I'm still confused, if you apply stucco to the outside, wont it hide the bricks anyway? You do not have to build a roof if you render the outside of the insulated dome. Is the round enclosure you are asking about like another dome on the outside of the insulated dome? or like a cylinder going straight up?Originally posted by Mike D View PostYes this is for the decorative enclosure, and the stucco would be to put on the top of the dome to seal everything in so I don?t have to build a roof. I just want to see the clean look of the brick.
are you concerned about the vermiculite concrete in the slab or on the dome not being able to bare the extra weight.Originally posted by Mike D View PostI was worried that the Vermiculite concrete wouldn?t be able to support the weight of the dome and a decorative brick enclosure. Would it dent or get compress? I could just make more of an island insulating layer, as to just have it under the dome but not on under the decorative brick enclosure.
If it is the insulation on the dome and you are building another dome over the top then the second dome should end up being somewhat selfsupporting should'nt it?
Re: Round shape
Dmun, Thanks for responding (I love this forum)
Yes this is for the decorative enclosure, and the stucco would be to put on the top of the dome to seal everything in so I don’t have to build a roof. I just want to see the clean look of the brick.
What do you mean about the extra support of the slab? Do I need the extra support in the middle of the slab or on the sides and back inside the normal blocks? Wouldn’t the decorative enclosure brick be mostly or almost on top of the blocks around the edge?
I was worried that where the decorative enclosure brick joined the vent area it would get too hot, and that a different mortar would be needed. I guess I could just use a high temp in these areas, right?
I was worried that the Vermiculite concrete wouldn’t be able to support the weight of the dome and a decorative brick enclosure. Would it dent or get compress? I could just make more of an island insulating layer, as to just have it under the dome but not on under the decorative brick enclosure.
Mike
Re: Round shape
If these questions are about the decorative enclosure, one course of bricks is fine, as is regular type S mortar. You need extra support to support your slab, either another course of bricks, or a course of four inch blocks up to the height where you pour your slab.
Vermiculite concrete is lightweight.
I don't understand your stucco question. I thought you were planning a brick enclosure.
Round shape
I am very close to starting but I have a few things to work out first. I want to close in the dome with a round brick form, kind of like Balty Knowles. I went to Pizza Bianca in Phoenix and fell in love with their round shape. I need help on how many bricks thick I need to make this enclosure (so I can build the base and slab appropriately).
-I think Balty Knowles did 2 bricks, is this necessary (can I get away with just one brick, or will this be too unstable)?
-Do I need to use cored bricks (the ones with the holes in them)?
-Do I need to use High temp mortar?
- If I use vermiculite/concrete insulation on top of the slab, will it support the weight of the bricks? I read somewhere that this type of mix is a little spongy?
-I was planning on filling in the top with extra insulation and covering it with a stucco type cap.
Any thoughts?
MikeTags: None
