Has anyone built an chimney that works while the door is fully closed? As I take it, you have to use your oven with the door open and only close the door once you remove the fire. However, I was thinking about making it so that there is a small opening from the fireplace into the chimney so that smoke can escape while the door is fully closed. Good/bad idea?
