Dannos Limey Build (Suffolk UK)
  • Bookemdanno
    Re: Dannos Limey Build (Suffolk UK)
    Now...where were we...
    Lots of rain here, but i've kept going where possible on areas around the oven.
    Made a rain cap for the chimney flue from the front panel of one of the storage heaters, that gave up its bricks...
    Just a little bit more work on the oven area, then start work on the chimney vent and entrance! I've knocked up a support for the brickwork based upon the support for the oven arch, so i'm ready to go when i can!
    Bookem,
    Nothing wrong with the rustic category, I am sure the pizzas taste the same.............fun build to watch. Keep the pics coming.
  • Bookemdanno
    Thanks for your kind words!
    The form worked out okay really, with the only downside being you couldn't see the internal face of the bricks to clean and point. I covered the form in polythene to keep the water off the ply which compounded the issue further really. Speed wise, and for ease of bricklaying the form is the way to go. I went at it pretty "gung ho" as i was fed up with brick cutting by then but in hindsight, a little more forethought and more tapered cuts would have been nearer my level of perfection for this dome. Still pretty happy with the end result though, it fell into my "rustic" category!
    Good luck with your ongoing build.
  • flyfisherx
    Very nice rustic looking dome! Looking good. I hope to be where you are after I get back from vacation. Nice work. How did the form work out for you for the last few rings? I am debating using this method or not.
    Dave
  • Bookemdanno
    The Keystone was finally dropped in and the larger outer joints filled and pinned with offcut wedges of brick until it was all tight. Then a little left over mortar smoothed over. 24 hours later, George was removed.
    Quite messy, but the Hydraulic Lime mortar stays in the "green" stage a lot longer than Cement based mortars, which allowed most of the drool to be cut from the brick face with a pointing trowel. The head and shoulders in the oven pointing technique seemed to create a lot of fun with the kids pulling at my hairly legs!
    Some of the joints became a little matched and over large, but mechanically i'm convinced it is sound. I hindsight, i'd taper cut more of the final chains. Maybe next time!
    Either way, i'm very pleased with my rustic little dome and always stop for a peek! Things now move away from the oven for a while to clad the base and build some of the bbq area attached to the Oven.
  • Bookemdanno
    Moving on...
    "George" provided a much swifter solution to brick laying but i didn't like the fact that i couldn't see inside, or point as i went like with the itool.
    Maybe it would have been easier without the polythene i covered George in, but i couldn't risk too much water soaking into the woodwork. The old bricks are pretty thirsty. Closed the dome in an afternoon.
    The final chain was tapered, and the keystone created and cut from two half bricks bonded with Hydraulic Lime Putty. This was along the principle of what the victorians used to build gauged brick lintels.
  • ggoose
    Nice looking build McGarrett That is a fine arch! I wish my mortar joints were as uniform...
  • Bookemdanno
    Not a great deal more has been carried out, due to wet weather.
    Trimmed up the arch, for the dome transition...
    Laid a few more bricks in the chains...
    And got creative with my jigsaw to make a form for the last few chains. The itool was a bit slow going for me.
    I've spent the evening chopping up bricks for the next few chains, so i'll hopefully be close to closing the dome, this weekend.
  • Bookemdanno
    I'm not that speedy, i was just a bit slow in setting up my build diary on here.
  • Faz
    I'd better get a scoot on as you're starting to catch me up!! Looks very good
    Bookemdanno,
    Umm, you must older since I watch the original Hawaii-five-o too. Your build is progressing much faster than mine. Your courses seem to grow daily. Fun to watch your progress. As far as Hawaii, I can always visit for I like the four season of Utah and you don't get "rock" fever on the mainland.
  • Bookemdanno
    And to bring this thread up to date, more rings have been added and this is where i'm up to as of 19th June!
    I laid the ring courses on just a half bed towards the inner edge of the oven, and then wedged the bricks in place using small sections of quarry tile until the mortar set up. Removed the pinings, and then pointed the larger joints with a new mix of 3 parts sharp sand to 1 part NHL 2. Sharp sand over here has larger more angular particles which can be used for thicker joints as the resultant mortar is more able to withstand shrinkage cracking, creates a stronger mortar and doesn't slump as easily.
  • Bookemdanno
    An insulating layer of aerated concrete blocks, mixed with a section of reclaimed Kiln Insulating bricks centred at the the oven were laid next.
    The heater bricks were set on a slurry mix of 2 parts Kiln Dried Sand to 1 part NHL 2 Hydraulic lime. The Kiln Dried sand has a fine sized aggregate, which i used to allow a thin bed of mortar.
    Next step was set out and cut the reclaimed quarry tiles to cover the heater bricks and provide a cooking floor.
    A mix of metric and imperial sizes tried to cause problems, but a bit of jiggling about and a not too far off rustic "pre-loved" cooking floor was produced. Again laid on the Kiln Dried sand Lime mortar.
    I ripped down an aerated block to Heater brick thickness for the vent floor, to isolate the heater bricks within the oven section, creating part of the thermal break. I've had to stop short of completing the vent floor until i complete the base brickworks.
    Arch layout...I didn't like the full half brick arch that i originally set out, so got a bit creative with the angle grinder and produced some voissoirs.
    A much better end result. So got to work laying the first course, and arch.
    Bricks were laid on a 2 parts soft sand, 1 parts sharp sand to 1 part NHL 2 Hydraulic Lime.
  • Bookemdanno
    Thanks Russell, yes of the original when i was a kid and i didn't even mind the re-makes!
    Thanks for the heads up on treasure archives too!
    I visited Hawaii, Maui and Oahu for 3 weeks in 2001. Why on earth did you leave!?!
    Welcome,
    Must be a Hawaii Five O fan? Originally I am from HI. Anyway your build is looking good and their is nothing wrong with doing a build on a limited budget. You are the second one I have seen using storage heater bricks so I am watching with interest. There has been some lively discussions on this but IMHO your forge ahead with what you have.
    Check out Lburou's "treasure archives" in the newbie section, it is a great reference for some of the best builds on this forum.
