Yes I can get Portland cement David and I've sourced lime as of today.
So are you saying I can use the home brew with this 1000 deg C fire cement I have?
I will purchase some Lime and fine sand and give the home brew another go.
I did attempt the home brew but it was with a sand/lime premixed, but it failed to work.
Thanks for the that anyway David
Colin, thanks too for your input I shall shim or endeavour to get joints closer, but first I will purchase a bag of lime to experiment with.
Paul
