Re: Irish Build
well 1 area did leak so i routed them all out and then re filled them again. were tiny cracks but some were after pushing mortar out of joints as heat was too much
just got awful 2 days weather so lot rain got under the tarp i had over it.
need try get it waterproof when back
Re: Irish Build
sorry to hear about the cracks. are you seeing any heat or smoke escaping through the cracks? maybe they are exterior superficial?
If no smoke or heat escaping, try to fill before you leave, the mortar will cure before you return, then go slow on your next firing.
Re: Irish Build
Found few more cracks. I am on hols next week do so no cooking until i am back. Hope cement not falling off i side as some crumbled after got too hot
Lovely build pic like the black can
Re: Irish Build
I was usung home made black pudding chopped up with chili sauce
Re: Irish Build
I enjoyed reading about your build. Really some nice brick work. Keep the pics coming. Any different recipe for irish pizza?
Re: Irish Build
both there is a bbq on left and inbetween bbq and oven a prep area
Re: Irish Build
will be fitting 3 at weekend so works at about 3inch thickness
Re: Irish Build
Originally posted by john_aero View Posti plan on wrapping it all in 3 iches of ceramic blanket (equiv to 6inch vermiculte concrete per fono build pdf) and the stucco it. i had planned build barrel tye oven thats why my base is too narrow and have try squeeze outer layer in, going to be tight though
red brick chimney will also be built in the front. but want dry all out and make sure its ok before go finishing it off
Re: Irish Build
Re: Irish Build
here is the cracking
after 3 -4 hours steam and damp was evident around cracks but no smoke came out of them
seem sound hollow to tap.
also sonly one is smoking, the one marked in blue marker.
looks like its all around the area where the 3 last bad chains were
brick cracking going vertical is on the right hand side when look in door.
blue marker is directly at the rear top when look in door and other one is over arch
the circualar one is evident from top6 Photos
Irish Build
So got oven built last week, wont bore people with base construction as we all know a slab of concrete is not most exciting part.
Ok so i ordered 180 bricks for a 90cm or 36inch oven.
only used about 120 in total.
about 40 for floor (cut to fin inside walls)
and 80 for down ( i know i should have tapered bricks that way be better joints and would used more bricks)
all bonded with the home brew 4:1:1:1 mix
It started hammer down rain near end so foolishly rushed the last 3 chains and they look god dam awful
took time do part over the arch but looks awful. its insdide and wont be seen anyway more i know its there
left dry for 4 days under a tarp.
then had candles in it for 48 hours solid.
yesterday started curing with small fires but timber i think must have been damp as got lot smoke and soot inside.
Also fire got fairly hot 2 hours into it when i went for a walk and when came back there were lot cracks, 1 of which is leaking at the join between 2 cracks.
there then came few more that look be following brick joints.
also one over arch so not very please as fire must got very hot.
kept it going for 5 hours then left embers in it over night with door half blocked up to keep heat in and the cats out.6 PhotosTags: None
