Re: Crack in structural slab. Bummer.
The crack appears to run from side to side only.
The support might have stayed underneath the slab for maybe a week or so.
My idea to put blocks underneath is indeed to prevent collapsing if it comes to that.
Does this crack run from side to side or front to back?
Originally posted by deejayoh View PostWondering how you are so sure about that?
Looking at a pic of his full oven, if the cracks are on the right and left side of the oven, and there are no cracks in the foundation, I don't see how it would be any sign the concrete is failing. I also don't see how a wall at the center of the oven would help.
Yannick,
Not sure what is going on with your support slab but here is a post I posted a while back. It may help you understand why your getting cracks in the dome stucco. A very informative article on the stucco process.
Originally posted by kbartman View PostGlad to see your enjoying your oven. I've been enjoying mine also.
Did you finish your stucco yet? Hope to start my stucco process soon. I been doing some research on the process. Attached is article on best practices if you are interested it was quite a eye opener for me glad I read it before I attempted anything. I hope your still in the planning process.
Too big to post the pdf file here's a link http://c.ymcdn.com/sites/www.nibs.or..._011_WB4-2.pdf
The foundation is not cracked.
Just the slab beneath the oven.
I cannot see if it is cracked underneath because i still have the backer board.
I haven't noticed the slab cracks before the fire started.
I might grind them and patch them estheticaly but i think I will still add those blocks underneath the slab.
I thought about doing it during the contribution but I thought all those rebars should hold up. Better safe then sorry.
Originally posted by Yannick View PostThis morning I took a little tour around the oven and found a crack on the structural slab of the base, under the vermicrete.
Slab is 3.5" and rebar reinforced. The Vermicrete is 4".
I have a crack on the left and right side of the slab (see picture)
Picture1: crack on left side of slab[ATTACH]44464[/ATTACH]
Picture2: crack on right side of slab[ATTACH]44465[/ATTACH]
picture3: crack on the right of the oven opening. I keep adding stucco but the crack still shows up.[ATTACH]44466[/ATTACH]
Picture4: crack on stucco side.[ATTACH]44467[/ATTACH]
My course of action for the slab is to build up a wall inside the base, in the middle, to support the slab. (maybe going from the back wall of the base towards the front for half the length of the inside .[ATTACH]44468[/ATTACH]
Puzzling....
Unless there are cracks in your foundation, I am thinking that your front wall/brick arch might be weak. Rather than the arch, a concrete lintel might have been better.
Not sure if your support wall is best solution. The cracks may just be minor stress cracks and as long as they don't get worse, you might be ok. However, am curious why stucco keeps cracking, which would indicate that it is still moving.
Maybe a concrete expert will chime in here.....
My course of action for the slab is to build up a wall inside the base, in the middle, to support the slab. (maybe going from the back wall of the base towards the front for half the length of the inside .5 Photos
