Originally posted by waynebergman
View Post
We use wood as our principle source of heat in our home. Also we use alot of arbutus (madrone to us south of the border) as well as maple, alder, wild cherry and of course fir. Once we cut and split our wood we always endeavor to get it under cover ASAP unless it is spring or early summer when we allow the wood to dry in loose piles in the sun before moving to a covered area. Madrone is an excellent heating wood for the home and I have high hopes for it in our WFO (once completed :-)
The advice given to you sounds alot dependent upon your local geographical area as well as to when it was cut. Spring heading into summer and hopefully drier weather it would most likely be fine but personally I would have it under cover by onset of wet weather in the fall. If one followed this advice with wood dropped in the fall I cannot see much drying occuring over a winter if is left exposed in an area with alot of rainfall. Sawmills (without ponds) have sprinklers on the logs so they don't dry out. Dry wood is much harder to cut.
Madrone is not prone to rotting like cherry so leaving it piled in contact with the ground won't be a problem. We try to dry/age our wood so that wood gets a full summer to dry. Wood cut in the spring can be burned in the late fall; wood cut in the fall isn't burned until the following fall, a year later. Also madrone seems easier to split when wet as opposed to being left in rounds.
Wiley
, and I'll look forward to seeing the result.
