See link to youtube video showing the string tracing the internal diameter is pretty close all around. Seeing the very last part of the video I'm not so sure that those cuts connecting the wall and the arch will do. So tricky to cut those and I rushed it TBH.
Click here---> https://youtu.be/26PuF0zINR4
It's going to take the IT to make sure that all is lining up. The IT has the ID of your dome built into it. It is the best tool that can tell you where the compound curve of the dome will be in relation to your arch. The OD may not work out perfectly with the slope. You can fill that in. I like cutting the arch brick to fit the ID of the dome before attempting the slope.
EDIT: We were posting at the same time. I will wait on the pic.Last edited by Gulf; 10-18-2020, 04:26 PM.
Originally posted by Gulf View PostIf you could take a pic from directly above and dead center of your dome, I might could use it to help explain at least some of the factors that goes into this concept. I promeise you, once this concept clicks, it wil be a "ureka" moment for you
Mike
- 1 like
Originally posted by Gulf View PostHow does it work out when also using the IT as a guage?. Do a search of the forum using the terms "inner arch placement" Tht should bring up some threadsthat may help explain what I am asking. JRPizza , UtahBeehiver, and others have explained this much better that can I. Here is a post with a pic that Russell shares a lot. It is a very good example of the appearance of a segmental arch such as yours.
When I swing the mason's twine along the edges of the bricks it matches across all the rear parts of the arch bricks. Some small adjustments could be made but not a tone. In comparison to the photo that you linked, the faces of my bricks are pretty small; I don't know if that matters.
That said, when I look at it... something doesn't seem quite right and I'm not sure whether that gut feeling has anything behind it.
Is it correct that courses 5 and 6 will intersect with the arch bricks? Because thats how my bricks are lined up.
- 1 like
How does it work out when also using the IT as a guage?. Do a search of the forum using the terms "inner arch placement" That should bring up some threads that may help explain what I am asking. JRPizza , UtahBeehiver, and others have explained this much better that can I. Here is a post with a pic that Russell shares a lot. It is a very good example of the appearance of a segmental arch such as yours.Last edited by Gulf; 10-18-2020, 04:12 PM.
- 1 like
Originally posted by mongota View PostYour taper cuts look terrific from the front. Nice.
Looks like you have an anchor string in there already? Using a string pulled tight and held between the bricks, the red star should be the inside radius of your dome, the yellow the outside radius of your dome.
Your work looks quite nice!
Will post back when I get things sorted!
Hope the photo helps clarify Joe's remark...
Getting the arch done and covered will be a huge relief.
- 2 likes
On second look, It looks like all your inner arch bricks are all the same cut. That shouldn't be, if the they were cut individually with the IT to fit the compound curve of the dome.
- 1 like
From what I see, it looks pretty good. What I can't see, and don't know, is if your your inner arch placement is where it shoul be from the center of the dome? That may be covered in some of your other topics. It is best to have all of that information in 1 build thread as opposed to multiple topics. It makes it easier for us that have some experience to critique and much easier for new builders to follow.
- 1 like
Originally posted by Gulf View PostClose enough imo
