42” Pompeii oven and Argentine bbq on California Central Coast
Russell thanks for the reply. It looks like you really have two arches that make the gallery. The outer and the inner horizontal bricks. As the outer arch is purely a architectural and continuous I am not concerned with that. With regard to the gallery is there a 1” brick at the front and the back at the top of the horizontal brick arch to keep the horizontal gallery bricks in tension and create a flue hole? I would need to see the top view of the gallery before you placed the flue box bricks. Below is a quick sketch to show 1” bridge brick front and back to support the gallery arch and ultimately the flue box. Am I on the right track?
Hello all, I have been quietly making progress and am close to closing the dome. But the part I just can’t seem to get my head around is the interface between the inner arch, the outer arch and the flu box. In some photos it appears the outer arch is really a double arch and in some photos it butts the inner arch to allow for a thermal gap.
I guess my question is how do you span from the face of the outer arch to the face of the inner arch with the bricks that make the sides of the flu box. I will be using an 8” dura tech flat plate to mount the chimney pipe to this structure. And my bricks are a standard
9 x 4 1/2 x 2 1/2
Any help would be greatly appreciated.
Michele
The downside of uneven heating is uneven expansion, and with brittle materials resultant cracking. It's why a glass plate will explode when placed on a burner but won't if slowly heated in an oven. The thought is insulation helps keep the heat and expansion more uniform.
- Likes 1
My grandfather once told me “ it is better to remain silent and be thought a fool than to speak out and remove all doubt”.
Well here goes. It is my understanding that thermal shock is caused when a material is heated and expands beyond it’s elastic capacity. Most often cracks occur by heating a material too quickly. I am not sure why an insulated layer would prevent that. I would like to see the chimney sweep video with an insulation blanket around the clay pipe. I am guessing that at that rapid acceleration of heat it would have still cracked. I really don’t know what I am talking about but it is fun to speculate.
- Likes 1
Watch this on thermal shock.Originally posted by Michele Enrico View PostMr. Slowhand slowhand and MarkJerling interesting information about the cracking. Maybe it cracks anyway and you just can’t see it because of the insulation. haha
There are a lot of brick ovens out there with no insulation perhaps warming the oven more solely might help avoid temperature shock.
Michele
While a brick oven has much thicker walls than a flue tile, the same principle applies leaving an uninsulated oven more vulnerable to thermal shock (cracking)
MicheleLast edited by Michele Enrico; 08-29-2022, 12:13 PM.
Michele Enrico, I must agree with Mark on this one. Having spent a lot of time on this site, before starting my build, this is one of the general knowledge you pick up. The isolation is important for structural safety of the oven as much as it is for the heat retention. Having said that, there are more experienced builders here, that would give you advice.Originally posted by MarkJerling View Post
It's said that, with no insulation, when fired, the bricks are much more likely to crack due to the differential from hot to cold, inside to out. I don't have any proof for that, it's just what I've read here.
Again, excellent craftsmanship, keep up the good work!
It's said that, with no insulation, when fired, the bricks are much more likely to crack due to the differential from hot to cold, inside to out. I don't have any proof for that, it's just what I've read here.Originally posted by Michele Enrico View Post....I am not intending to use the oven for long term baking so I may leave the structural bricks as the finished exterior.....
mongota, thanks for the tip. When do you recommend going to 1/3 bricks?Last edited by Michele Enrico; 08-29-2022, 12:11 PM.
That's a really nice complement Mr. Slowhand. Thank you. I am not intending to use the oven for long term baking so I may leave the structural bricks as the finished exterior. That said the trick is a heavy duty sponge. I scrub the days work with a wet sponge after the concrete has set firm but still green. Any residual after it is totally dry can later be cleaned up with diluted muriatic acid.
I wish the interior view of bricks in my oven are as clean and nice as the exterior view of your bricks Michele. Excellent craftsmanship, looking forward to see this one done!Originally posted by Michele Enrico View Post
