Yep - mine is the same. I probably didn't add enough concrete mix to the vermiculite.
To set my floor I put a scratch coat of refractory mortar, then leveled it off. After it cured I put a layer of fireclay/water and set my floor bricks. I then mortared my soldiers to the scratch coat.
If you go with the FB board (CalSil) under your floor the small voids could be filled with dry fireclay
Originally posted by briot
View Post
